Body bolt Blues.
Body bolt Blues.
Hi everyone.
I'm having a problem with the last 2 body bolts and have no idea how to get them off. These are the last 2 behind the wheel wells. The bolt turns, but doesn't loosen. I'm thinking that whatever holds the nut still, broke free. The problem is: I can find no way to get to the nut to hold it from spinning when I loosen the bolt. I looked in the manual and still can't figure it out. Any help will be greatly appreciated !
I took a picture, but for some reason, can't download it from my phone.
Thanks,
Dom
Thanks,
Dom
I had the same problem. I used a torch and burned off the bolt head. I packed the area with a sopping wet towel and just left the area of the bolt head exposed. No damage to any fiberglass the towel was starting to catch fire but it wasn't too bad. It took less than a minute to do.
Caged nut
There is a caged nut inside the car. Pull back the carpeting and you will see the nut. The weld on the cage has either broken or rusted off. Soak the nut with Bead Blaster or Liquid Wrench and put a vice grip on the nut. Have a helper hold the vice grip while you back the bolt out. Mine were so rusted, that I ground the bolt heads off. Unless you are restoring an NCRS car, you don't need the cage to hold the nut. They were used to aid in the assembly process. Jerry
I tried feeling around the top and sides of the frame from underneath and couldn't find anyplace to get to it.
Thank you again !
Dom
The wet rag idea is a good idea. (I'm being serious) And, I have 2 fire extinguishers in the garage.
Thank you.
Dom
My two problem bolts were the two in front of the rear wheels in those two pockets with the covers. The key was the wet towels if it wasn't for those the car would have burned to the ground.
Dom
I used a die grinder with a cut off wheel. When the bolt was cut I simply jerked the cage out with some vice grips. I've been known to be a little hasty.
The cage nut is only there for convenience on the assembly line. There is no need to replace it. Just will need someone to hold the nut when you put the body back on the chassis. Cut the bolt and drive the remainder up and out of the cage.
I'm probably going to try sawzalling the head of the bolt off.
I removed the cage. (accidentally) The nut is in such a position that I was having trouble holding it with anything. Finally got an adjustable on it. I squirted the hell out of it, and the right side, with 3 different types of penetrating oil tonight. Have to wait till tomorrow night to try again. I still have to remove the left side cage. But, at least I know where they are now. lol
Thank you all for the help !
[QUOTE=DomL64;1587428681]Thanks Jerry.
I removed the cage. (accidentally) The nut is in such a position that I was having trouble holding it with anything. Finally got an adjustable on it. I squirted the hell out of it, and the right side, with 3 different types of penetrating oil tonight. Have to wait till tomorrow night to try again. I still might have to remove the left side cage. But, at least I know where they are now. lol
After squirting the heck out of both sides with 3 types of penetrating oil, I will have to wait till tomorrow night to give it another try. Then…..
Off with it's head !
The body is loose !
Thank you for all your advice. The left side body bolt came free with a lot of WD40 rust stuff.
Fortunately, I made a 3/8" thick aluminum piece to hold one of the other square bolts and it worked on the left side. The right side….. Sawzall. I turned, and turned the bold head but, the nut turned also. The vice grips couldn't get a great grip and kept falling off.
I'm glad I had a battery sawmill. Now, it's all loose. Except for the sped cable that I can't get off. That's next !
Thank you all again !
Thanks !
Unfortunately, it won't fit in the tunnel between the linkage. I can't even get my fingers in there. I'm almost resigned to removing the linkage to get to it. Almost.... lol
Thanks again !
Dom
The people on here are VERY helpful !
Even with the books and Noland Adam's video, there's many little tricks.
Thanks again !
