Tires - advise needed
My 65 C2 has Coddington 8 X 17 wheels This is a recent purchase and the tires have about 20% life left. My car is a driver but only on choice days. Ride quality not high performance is what I (my wife) is looking for. She loves the car but wouldn't mind a little less shock. We have owned two C1's in the past so she is not a newbe, just a couple of decades older.
Any advise will be appreciated.
If your after 15`s I can make a suggestion. 16, 17, or whatever I cant.....215-65R-15`S with a 6 inch rim is what I found to be wide enough and lower than 70`s or 75`s....To me the taller tires make them look funny, especially from the rear.....
Find a picture of my 62 here on the forum
Blueglass - Does your 65 have flared fenders? I suspect you don't have stock fenders otherwise you'd be hard pressed to put an 8" wide rim under them without raising the body up a bit with spring spacers.
My two midyear Coupes have stock wheel openings and both have KO's and for that sized rim (6-inch width), I run 215-65x15's on both.
Mike T - Prescott AZ
The tires on my car now fit fine but are really rough riding. They are getting close to replacement so comfort not really high performance is what I'm looking for. The wheels on my car now, I think look good. I want to change tires only. The suspension has been modified, composite rear spring etc but the body is stock, no flares.
Thanks for your reply. PS - If you remember, you gave me advise regarding the breather system on my 502. I put two BS breathers on the left cover.. The PVC is on the right. All good ! Thanks again !
Thanks again
C2 of Year Finalist (performance mods) 2019
8 inch wheel can work. Usually you need to relocated the e-brake bracket on the trailing arm and an 8 inch wheel with 4 inch backspace will be great. In the front, you can also use this same wheel, but you may have frame rail rub at full lock. I have 16x8 with 245/45/16 tires and have no body rub issues but do "polish" the frame at full lock in turns. The biggest issue is that these tires are short. Only 24 and a half inches tall. Stock tires are about 27" tall.
The only way to get a better ride is likely to get a taller profile tire, and I doubt that will fit. What is the current size and model tire you have now? We can possibly advise a different brand or model that is quieter.
Thanks for the reply ! I'll post on Sunday
