Need a refresher course on installing door glass
It's been a while since i installed door glass in a coupe and I need a breakdown of the order of installation before i begin installing the components.
If i remember correctly, the procedure should be:
1. install the felts that sit inside the rear and upper channel with the rear track first.
2. Install the track
3. Install the vent window
4. install the door glass
5. and finally install the window wipes and inner felts
Or does the door glass go in first then the vent window?
Thanks!
Thanks!
Thanks!
Thanks!
Then adjust the side window front track and rear tracks and that part is done
Thanks!
Thanks!
Final piece to go in is the rear vertical track.
Outer wipe should go in before any of the above IIRC.
That does it dammit.
When are one of these smart vendors (Wilcox mebbe) going to offer to take all of David's stuff and put it on CD-ROM for sale ?? Everybody wins, the stuff is all in one place and David isn't spending all his time burning CDs himself...and gets a check...
Anyone ?
Anyone ?
