64' center console repair kit
How do you remove the original sections and replace them with center console from one of these kits? Ashtray is obvious, but what about the large plate through which the ashtray is inserted.
http://www.corvetteamerica.com/cf/di.../item_1779.jpg
Or what method would be good to use to remove scratch from the plate with the ashtray and shifter indicator? Thanks.
Received 2,132 Likes
I think I understand you questions. Start by removing the side panel on each side of the radio, then slide the console up and out. Put the shifter in either 2nd or 4th for max clearance . The components have adhesive on the back of each. Just peel the old ones off the console, clean up any leftover glue and attach each new one. Reinstall console. Dennis
Received 1,050 Likes
C2 of Year Finalist (appearance mods) 2019
Sometimes the original plates and glue is tough to remove. A small screw driver to get it started and small vice grips pull and twist, clean glue with thinner.
I used a hair dryer on high to remove that glued down insert. Get a corner started, and then grab it with pliers and slowly pull while applying heat to area.
