The ignorant BS'ers can be quite entertaining
It's a SB400, bored .030 and stroked .100.
In the "old" days of modifying SB400 engines, it was fairly common to offset grind the rod journals down to small journal size on a 400 crank to achieve the additional stroke of .100in. This, with the .030 bore, gives about 418. With a .040 bore, you get 420----------------------which is what I have in my jet boat.
Right now, the SB400 in the 56 is only bored .030. But when it comes time for a rebuild, I'm going to open it to 420.
Received 6,547 Likes
C2 of Year Finalist (track prepared) 2019
That SBC hemi looks incredible. I had no idea.....
However, Chevrolet wasn't the only outfit to consider the possibility of a hemi conversion. Here is one with definite "Ardun" overtones:
Jim
Jim
I hope this isn't hijacking the thread, but it seems like a "fluff" one so I will chime in about the Hemi heads. I am not mechanically inclined but have been reading up and trying to have a basic understanding of how engines work. Am I misinformed, or is there very little advantage to Hemi engines? Seems like a lot of hype. My apologizes to any Mopar guys here.
There's nothing inherent to it...my (long gone) Ford Focus had a hemi. In the US it was called the SPI engine, but in Europe it was the CVH...guess what the H stood for! And no, it was grossly underpowered even for a car that size.
The advantage to the hemi was the valves were usually positioned such that the air flow had a pretty straight shot in from the intake manifold,a nd a straight shot out to the exhaust manifold, without flow restricting bends in the runners, and centrally located spark plug for a uniform cylinder burn without a need for quench area.
Now, you can have a hemi head that doesn't have straight shots to the runners, or a centrally located plug, so a hemi doesn't automatically make more power, there are probably more poor hemi head designs than good ones.
Doug
Doug
2023 Restomod of the Year Finalist
Wow, didn't know that about the Chevy hemi, very interesting, and the 418. I try to read every post because I usually learn something from each of them. Of course, remembering what I've learned is another matter...
