Who Can Supply a Correct Lenght Dip Stick '66 327/300
I am having trouble finding a correct replacement dip stick for my '66 327/300 engine.
As I understand it from my research the upper tube should be 9" long, natural finish.
The dip stick itself should have a rounded handle, natural finish and should measure 20-5/32" from the seal surface (where it contacts the end of the tube) to the "Full" mark, and 20-59/64" to the "Add" mark according to JohnZ.
I have the correct 9" upper tube now but the replacement dip sticks I've found so far are all too short, measuring 19 1/2" to the full mark.
The short one is what's in my engine at present and obviously it doesn't give an accurate measurement.
Does anyone manufacture/supply the correct appearing and correct length dip stick for a '66 327/300 engine?
Thanks everyone for your help with this.
Thomas
Thomas
Received 6,986 Likes
2015 C2 of Year Finalist
have you tried Paragon or LIC
I couldn't get Paragon to confirm the length. They did note that they were called replacement, not correct and that the handles on theirs were painted black with black plastic plugs on the ends.
The fellow I talked with at Keens was very willing to pull one off the shelf and measured it. He confirmed it was 19 1/2", also with a black painted handle.
I looked in LIC paper catalog and they show black Tip/no dimple for 250-300hp, 65-66, and an unpainted/black Tip/no dimple for all '67's. I'll have to call them tomorrow to see if they're willing to pull one and measure it.
While my car is far from NCRS correct, I try to use correct replacement parts as I am able when the need arises.
Many thanks for the suggestions.
Thomas
Thomas
Paragon normally will go out of there way to help you get the right part.
Again, my thanks to you for your help.
Thomas
Thomas
Thomas
Verne
Thomas
Tom,
This one has the right measurements but I thought by '66 they used a different type of sealing cap, either all rubber or a metal can with a seal in it. Maybe someone else will know for sure.
Verne
Verne
Tom,
Verne
Attachment 47791286
Verne
Attachment 47791286
This is the type/style I need. As of now it appears I've located a correct, nice used one which will work just fine for my purpose. Interesting that I can't readily find a supplier with the correct one.
Thanks everyone for your help. This forum and the C1&C2 section especially, is populated with a pretty great bunch of guys. It's such a terrific resource.
Thomas
[QUOTE=BB767;1586799099]I am having trouble finding a correct replacement dip stick for my '66 327/300 engine.
Thomas[/QUOTE
sent pm
Thomas[/QUOTE
sent pm
Received 1,859 Likes
You can't find a correct one because 1) GM stopped making them over 40 years ago, and manufactured a different Service part instead (stick and tube) to service the application, and 2) Nobody has seen fit to invest in the tooling to reproduce it due to the low volume.
I was just talking with Verne the other night about that very subject and that's the conclusion we came to as well. Not much of a market or need for them. The originals stayed with the engines for the most part and re-conditioning one is fairly straight forward for those that need a pristine one for a Top Flight car. A nice pre-owned; "used but never abused" one will work nicely for my purposes.
BTW, you do realize that since you made that post everyone who has a correct NOS one, set aside in the deep reassess of their garage rushed to measure to confirm it's the right length and then tripled the price they were going to ask for it at the next swap meet.
Many thanks my friend for all you do for us Corvette aficionados. Hall of Fame indeed!!
Thomas
St. Jude Donor '06
Thomas,
Did you see this thread in the parts for sale section?
http://forums.corvetteforum.com/c1-a...-dipstick.html
Best of luck with the search. Tom
Thomas,
Thanks guys for the links. I knew certain Corvette items were a bit pricey but had no idea it extended to lowly dip sticks. My car is not entirely NCRS correct and looks like it will stay that way.
Thomas
Ummmm $350.......for a dip stick..... and they both have shelf wear. They must have read JohnZ post and really jacked up the price!!!! Nothing like trying to take advantage of your fellow Corvette friends. This reminds me of the saying, just because you can do something doesn't mean you should.
Thomas
Thomas
p.s. I agree on pricey for the original that's listed
Thomas
Thomas
Didn't you know that is at LEAST what I would have charged you if my nos one had been correct?!?!?!?
I keep looking at the avatar under your name and thinking "road trip, road trip".
Thank God when they designed the C2, they made it user friendly for a guy who's 5'18" tall.
Verne
Tom,
Verne
Verne
The '66 awaits your arrival and should even have a proper dip stick by then.
You claim you can fit in there and I for one believe you.
Thomas
