Ground for glove box light
I am trying to hook up my glove box light on my '63. I found the orange power wire (always hot) and understand how it attaches to the J shaped connection in the recepticle under the light bulb. All good to there. My question is : where is the ground source? Bulb holder appears to be intended to ground thru the metal light holder/lock striker attached to the glove box similar to all the other dash lights.
Problem is that the glove box attaches to the fiberglass dash opening; therefore no ground. Checking the wiring diagram I see something called "instrument compartment light& switch" which I assume is this light. Orange power wire only no ground.
What am I missing? Do I need to run a ground?
You're right the ground is the metal part of the switch into the glove box. There should be a little ground wire that runs from the left bottom of the glove box frame a couple inches to the birdcage below it.
My 65 doesn't have a ground wire connected to the glove box frame. The frame bolts to the z bar for ground. You can always run a ground if you need to.
Thanks guys. Still a little puzzled. I checked my full size glove box that was in previously and it appears to be a cardboard like material held in with screws thru metal speed nuts into the fiberglass dash. Not much conductivity for the ground to the light bracket. It looks like I will have to run a ground from Z brace directly to the light bracket
The light socket (with the plunger switch) is inserted through the glove box metal frame which is bolted to the Z-bar providing the ground. The glove box liner has nothing to do with completing the ground circuit.
Jay
713-253-0475
Kent is correct. I just did this same job on my 63 and there is not a separate ground wire of any kind. The bezel and socket should be one piece if it is an original 63 switch. When you push the socket and bezel through the hole in the metal glove box frame push the bezel firmly into the hole and then your ground is complete. That is all that there is to it. Call me if you have any questions. I am in Seabrook.
Jay
713-253-0475
Jay
713-253-0475
DZ
Greg Hollowaty (04-07-2019)
I pulled my glove box out again today. The light mounting bracket/latch striker combo does ground into the metal glove box surround. This surround is affixed to the fiberglass dash opening. There're is no metal contact with the Z bar. I have assembled the light as shown in Tom's diagram. If I run a ground wire from the Z bar to the surround, the bulb lights. So this is how I have done it As suggested, I have a connector on both the orange power wire and the ground to make glove box removal easier.
Thanks for all the suggestions.
xet (03-05-2021)
There is about a 3 inch gap between any of these "conductive" pieces and the Z bar.
Not sure how the hinge could ever directly bolt to the Z bar.
Obviously, the door is not original, but I would assume that would not impact this. The shallower glove box was required when I added the aftermarket air(VA), but when I look at the original box liner, it has no accommodation for contacting the Z bar. I'm guessing the glove box metal surround is OEM. This is a very early 63 car-VIN 2100+
Yes he is missing the large mounting bracket from the Z bar to the glove box frame. Look at the Long Island catalog and it should show you the bracket that you need. That will then complete the ground and the no ground wire is needed.
Received 1,857 Likes
The lower reinforcement/brace and hinge assembly that bolts to the face of the Z-bar didn't appear until about ViN 3700 as a running change.
Are you saying mine does not use the brace? If not how was ground achieved to the light? I seem to be stuck in a " do loop"!
Way too complicated. I dont have a wire in my glovebox. So I need to rip it out and go hunting. Nor is there anything remaining of a light. Was there a light delete option?
