What kind of brake fluid do I have?
2021 C2 of the Year Finalist - Unmodified
I noticed that the brake fluid is low in my '66, but I can't tell if it's standard fluid or silicone. Besides tossing it on my paint to find out the hard way, is there another way to test it? In the 80's I used silicone fluid and it was purple, but I'm not sure what's used now. Sadly, my brother recently passed away, and was the original owner of this beauty. So I don't know if he converted it when the calipers were replaced.
Sorry to hear about your brother...I'm sure he'd be super happy you're taking care of the car now...
I had the same issue when I purchased my '66 and wasn't sure what was in the system. Dot 5 is silicon based and won't mix with water so take an eye dropper and remove a bit from the reservoir and then add a little water to it and shake it up...If they mix, then it's a glycol based and if not (stays seperated and beads up), then it'll be the Dot 5...
Hope this helps...Good luck with the car. I hope having it brings you great memories of your brother.
Received 1,857 Likes
I mixed about an ounce of the mysterious brake fluid in a bottle of water and after shaking, it mixed in thoroughly together. No separation. So I guess I have the regular fluid. I also put some on a painted piece of metal and I'll see what it does to it over the next couple of days.
Yes it does.
The best thing to clean up a spill of regular DOT3 brake fluid is water. The water soakes it right up. If you spill it on paint, flush it off quickly with lots of water. If its silicone fluid, you will just make a mess with water. Also, with regular fluid, you can put a little in your hand and it will get hot - absorbing the moisture out of your skin. That's why you should never use old fluid or leave the cop of the can open.
You prescribed the correct test in your question - get an eyedropper,
take a sample and put two drops on something that's painted - if it doesn't eat it, it's silicone or something other than regular brake fluid.
