need wireing help
need wireing help
I lost all power in my 67 and the wireing at the horn relay started smoking anyone have this problem in the past. What should I check ?Thanks for any help
If you have ignition shielding, check the wires going to the coil from the ballast resistor. They often get cut by the sharp edges of the bottom of the shielding.
