Vacuum line for FI-setting timing
Received 1,843 Likes
I've forgotten what you have.
Received 6,513 Likes
C2 of Year Finalist (track prepared) 2019
If your engine has the "914" distributor, and it should, there is no vacuum line to disconnect; there is no vacuum advance mechanism.
Jim
Jim
Whats a 914 distributor?
possibly like a 62 FI with no can and dual points...right/wrong?
1961 Fuelie with 914 distributor...so no vacuum line to detach.
I got the timing set. Using a dial back timing light for the first time with digital rpm read out was awesome!
I really tried to help you a few times catch that you never mention the year car you're working on and that delays the correct answer to your question. Not a lot of people keep up with what car every forum name has.
