66 cross shaft question
Hello, my new cross shaft kit came with 3 stud seats. Am I correct in assuming that 2 go on the frame stud and 1 on the engine stud? Both get felt washer? This kit looks like a new and improved from the stock AIM, UPC 7 sheet C1
Thank you,
Al
Thank you,
Al
Received 1,858 Likes
The nylon seats (2) are only used at the frame end; the engine end only uses the square-section rubber O-ring that's part of the engine-side stud.
Than you,
Al
