Eletric choke connection 63 327 holley card
Received 1,857 Likes
When properly connected, the bottom end of the ballast resistor is the input side (12 volts from the ignition switch thru the grommet in the firewall), and the top end is the output side (reduced current to the coil + terminal).
Received 6,530 Likes
C2 of Year Finalist (track prepared) 2019
The series resistor serves to limit current to the coil and points. As a byproduct of limiting the current, the steady state Voltage you would measure at the (+) coil terminal with engine off and points closed would be less than battery Voltage.
Jim
