1967 tri power base what should look like,and who makes the best remanufactued
Received 1,857 Likes
This is the base that Paragon sells and their stuff is pretty much spot on. It's also very likely that most of the vendors source an item like this from the same manufacturer since it would normally sell in quite limited numbers.
https://www.paragoncorvette.com/p-34...427-w-3x2.aspx
Good luck... GUSTO
Good luck... GUSTO
