kick down likage
kick down likage
I have an ajustable kick down linkage probably not original, however, it has been working fine but came loose and slipped, I just need to know where it attaches to the transmission what position should the lever be in, should it be in the middle all the way back towards the rear or all the way up toward the engine. I just need to reattach it and tighten it back. Any help is appreciated.
Received 6,943 Likes
2015 C2 of Year Finalist
I assume you have a power glide
Here ya go hope this helps.
http://www.567chevyclub.com/images/5...powerglide.pdf
Basically, with the carb linkage open all the way, you pull the powerglide detent lever all the way forward (overcoming the spring tension) and insert the rod.
Chuck
