best way to put gas in holley?
want to get some fuel in holley before I crank over rebuilt motor, should I put it in thru the sight plug on side of bowl or thru the vent tube??
I like to use a plastic squeeze bottle with a pointed tip. The tip will fit the vent tube and not make a mess. You can buy them at Walmart or a dollar store and reuse them.
http://www.walmart.com/ip/Wilton-W11...-6-oz/24934853
Received 1,857 Likes
Easy!
An electric fuel pump. Why make it difficult!
Received 1,843 Likes
Right so why fool with an electric fuel pump or any of those other gizmos?
Just get in behind the wheel and crank it over about five seconds then pat the gas a couple times and you're on your way.
You guys that keep poppin' the hood to put gas in the carb will be on here sooner than later yelling that your hood cable broke (because you keep popping the hood) and you can't get the hood open! Help me! Help me!
Flavor injector at Walmart,, used one today after I rebuilt my Holley.
Quote,
"want to get some fuel in holley before I crank over rebuilt motor"
I think that you would want the motor to crank over a little while to build up the oil pressure on a new motor before it had gas in the carb. that might wash the cylinder walls if it didn't start.
Naturally
Quote,
Believe it or not... I use my pre-mix gas for my weed whacker. It's 50:1 mix gives a little upper cylinder and valve lubrication for a dry start up. Just splash a little in the primary throttle blade area, climb in the car, and crank. Once or twice is all it takes and the mechanical pump should have the carb primed at that point.
