Sparkplug wire set for BB with headers?
What is a good spark plug wire set for a 396 BB with headers.
The current set has straight plug boots which get burned by the headers.
Should I go for the 90 degree or 135, 8 or 8.5 mm wires.
There are so many sets available on the market.
My car has the standard ignition.
Ray
Ray
Location: going faster miles an hour...with the radio on in browns mills new jersey
I use the 135* boots and don't have any problems.
Wire size is a personal preference and other factors come into play.
In my situation the wire size was determined by the wire looms I wanted to use.
Received 2,127 Likes
Good wires should be rated by the lowest ohm resistance per foot. Dennis
If you want to use your AM radio, you can buy an undated repro set of 67 wires and use the braided shields on your new wires. You'll have to use 67 wires because these have ends that slip under the valve cover bolts; 65 and 66 wires clip to spark plug heat shields, which you can't use with headers.
