Ethanol Hates Carburetors
I learned that early on.
Any of the alcohol mixes will eat the Viton coating on your float needles over time. Thus I just run the higher end stainless ones, that don't quite seal as well in street usage, but who drives slow anyways! Other than that, I really haven't found a real problem, except alcohol contains more water moisture and the aluminum and such would tend to corrode quicker, thus I purge the carb and air dry it down, if I am going to have it sit awhile ( but currently my good carb is house art on a shelf in the back bedroom). I dust it regularly with my collectibles!
I know much has been posted about ethanol but I found this interesting and wanted to share it with you:
ethanol-hates-carburetors ==> CLICK
You know me, I'm totally against it! It may of been around for decades, but that's all one can say about it....
Got to run, talk later!
rustylugnuts
rustylugnuts
C2 of Year Finalist (track prepared) 2019
I make internal engine componentry for several of the Aussie V8 Supercar teams. They tell me that the series switch to E85 has increased engine maintenance expenses by 50%.
While this has been good for sales volume, ethanol is evil stuff and we won't allow any of our engine customers to use it...
I used to think that ethanol was a non issue in these older cars until about a year ago when my 396 had been in storage for several months, and I went to start it, it would hardly run. I opened up the almost new Holley street avenger and here is what I found:
I ended up replacing the carburetor as the internal passages as well as the power valve had been damaged. A few weeks later I was rebuilding a friends Holley and found the same thing on the secondary metering plate.
I am now convinced that ethanol is highly destructive and I will not run it in any of my classic cars without an ethanol additive - or preferably avgas!
Bob
Bob
Received 1,843 Likes
It ain't the ethanol, it's the water that can get in it if you are careless handling your fuel.
Ps. Did I mention the same thing can happen with straight gasoline?
My boat, jet ski, weed eaters and pressure washer sit for months (6 months at least, usually more) unused, half full of regular old ethanol gas in Florida's humid climate and start up with no issues when needed.... But I'm sure we'll hear from the sky is falling crowd very soon.
Yes it can, but it is the ethanol that absorbs water. BTW I live in the desert where the humidity is rarely over 40%. This was not related to handling of fuel at all!
Aaaaand .... we're off and running !
Bob
Bob
Post 14 is the important one:
http://forums.corvetteforum.com/c3-t...sion-fuel.html
more info:
http://www.pro-touring.com/archive/i...p/t-68563.html
I guess you didn't know that Holley has admitted that they had a production problem with the zinc castings and were replacing the carbs free of charge under warranty.
more info:
more info:
I don't think some of you not living in California realize!
That they play more games out here with emissions, gasoline and such than any other state. When the one forum member posted up those carb pictures, I said, I bet he is from California and sure enough, he was! They have always had weird emission crap here! We have Boxer and Feinstein!!!!! Thus if you would like some California blend crap to try in your cars, let us know and we will see if we can arrange that for you!
Nothing wrong with my mostly billet holleys, but I still purge it and air blow them down to dry them if not starting them at least weekly and running the gas in the carb out!
I went two decades not rebuilding a single tractor, car, boat, gas tool carb. Since 09 I have had to rebuild virtually everything. Saws, tractors, blowers, boats. I have probably rebuilt 20 carbs in 09&10. I think every mechanic said 'yeah, getting a lot these, ethanol". Started using marine stabilizer for ethanol in anything sitting more than a month. Except for one chainsaw in 3 years, no problem.
Ethanol is an issue.
Taking facts and twisting them doesn't make a truth. Ethanol has been around but take a look at the production / sales of it. Minimal at best until 2006
Now it is wide spread so everyone 'gets' to enjoy it
When your boat, lawn equipment, etc were built matters, as does the oil mix you use. Many boaters have been completely hosed because of ethanol destroying fuel tanks, lines, carbs, etc. same goes for lawn equipment, etc. these aren't myths.
The fact that you live in fl mitigates the problem on cars because they can be driven year round. Carbs like use in general, esp. With ethanol.
It's only 'new' in some parts of country and came as shock to many that they've been using it for years/decades, only finding out when pump labelling laws came into force.
2018 C2 of Year Finalist
St. Jude Donor '12-'13-'14-'15, '19
Next is the tin foiled hats....
http://injectorrepair.com/ethanol-problem/
http://www.fuel-testers.com/list_e10_engine_damage.html
rustylugnuts
rustylugnuts
