64 Coupe rear suspension
I'm in the process of replacing the rear wheel bearings, races and strut arm bushings. I took some pictures when I started, but I didn't have one facing straight up from under the car. When I removed the bracket the strut arms attach to from the rear end housing later I found that one side is straight and the other side at the ends steps back on the ends. My question is which way does the straight side face, to the front or the rear. Thanks Dennis
Received 1,859 Likes
I have the same question. It seems that the bolt pattern (4 bolts in the center) will work either way. So I have to ask on which side is the straight edge?
Received 1,126 Likes
Larry
Pierrie, Did you buy a disc brake kit, and where did you get
it from?
Would like to up grade my `64 coupe one day.
Your `64 is gonna stop now instead of darting
like the drum brake cars do.
Later Tony
it from?
Later Tony
Here's a picture of my rear end...(NOT NCRS, but the way I decided to do it)
RK
Luckily my vette is a 1965 so it came with disc brakes. I did have to replace my rear discs because one of them was too thin to turn.
It's a LOT easier to make the strut rod connections if you raise the trailiing arms up to normal ride height first - otherwise, you're fighting bushing tension in two directions due to the compound angles involved.
Thanks John!!
Most of us learn this the hard way and "after-the-fact"
However, once learned, we will never forget it again.
Sort of like the "dimple" on the distributor gear.
Larry
