1965 windshield dimension
Old 03-29-2014, 01:49 PM
colo69
colo69's Avatar
Default 1965 windshield dimension
I just cut out a rusted spot on both sides of my windshield pillars, and lost the measurements. I need some dimensions from top of windshield to lower part with out molding, inside to inside of frame would be good. maybe the middle to middle would be best, and corner to opposite corner, crisscross.
Old 03-29-2014, 03:09 PM
Mr D.
Support Corvetteforum!
Mr D.'s Avatar
Received 1,486 Likes on 1,003 Posts
Well just so happens my 65 is setting in the garage with no windshield or molding installed.
Let me see what I can get for you.
Old 03-29-2014, 03:48 PM
Mr D.
Mr D.'s Avatar
Not sure how much this will help but my measurements are;
Inside frame top to bottom is 17"
Inside frame center to bottom is 22 1/2"
Inside frame corner to corner is 47 3/4"
And those are assuming you measure from the same place I did!!!!!
Old 03-29-2014, 04:09 PM
colo69
colo69's Avatar
Default windshield
GREAT!!!!
Thank you so much, those numbers are the same as my numbers.
To 1965 windshield dimension
Quick Reply: 1965 windshield dimension
