What is the right carb gasket? 63 340hp Carter
Old 03-22-2014, 10:26 AM
donbayers
Support Corvetteforum!
donbayers's Avatar
Default What is the right carb gasket? 63 340hp Carter
Gang;
See pic of original intake for 63 340hp with correct carter 3461s carb.
What is the correct style of intake/carb gasket to use.
On another thread someone questioned that I might not have the right one.
Please give a part number if you can
Any help would be great.
Old 03-22-2014, 10:59 AM
MikeM
MikeM's Avatar
Received 1,843 Likes on 1,398 Posts
Your gasket should match the opening contour of your manifold.
Old 03-22-2014, 11:37 AM
DansYellow66
DansYellow66's Avatar
Received 2,621 Likes on 1,953 Posts
Yes, turn gasket 90 degrees.
I like 4-hole gaskets because I once had a problem with the intake whistling with an AFB on a 4-hole intake with a 1-hole carb gasket. But, with that manifold and the one side siamesed between the secondary and the primary, that is the correct gasket.
Old 03-22-2014, 02:17 PM
MikeM
MikeM's Avatar
I believe the original GM gasket was configured as I posted above. I don't know where you can purchase one though unless you happened to show up on my doorstep.
The gasket the OP shows is not the correct gasket and may cause a problem if he turns it 90*.
Old 03-22-2014, 02:23 PM
kingwoodvette
kingwoodvette's Avatar
Not being familiar with the Carter carb, I will ask the question anyway --will the 3 hole gasket for the Holley(2818) used on 64 & 65 work?
Paragon shows a separate gasket for the AFB on the 63 340 hp with aluminum manifold part number703. Bet that's the correct one.
Last edited by kingwoodvette; 03-22-2014 at 02:29 PM. Reason: Consulted the Paragon catalogue
Old 03-22-2014, 02:25 PM
MikeM
MikeM's Avatar
Different bolt pattern but otherwise similar gasket configuration.
Old 03-22-2014, 02:31 PM
kingwoodvette
Revised my comment after I looked in Paragon catalogue. See my post above.
Old 03-22-2014, 09:18 PM
DansYellow66
No, at closer look it can't be turned. I went though a list of Holley gaskets at Summit a few weeks ago and didn't see any 3-holers turn up. Another option is to make one out of gasket material if you want a 3-holer. A 4-holer should also work on it and you could trim it into a 3-holer.
Old 03-22-2014, 09:33 PM
donbayers
donbayers's Avatar
Thanks all
I went tO O'Reilly's and found a Mr Gasket #55 with the four holes. I trimmed out the larger side and this seems to be OK
Old 03-22-2014, 10:34 PM
kingwoodvette
Hey, that will work! Did the same thing with a 4 hole Mr Gasket thermal insulator under my carb
To What is the right carb gasket? 63 340hp Carter
Quick Reply: What is the right carb gasket? 63 340hp Carter
