lose of fuel pressure
Bad injector or check valve in pump isn't sealing. Possibly the regulator, depending on how it is plumbed.
Doug
Doug
I would agree with this but expect to see a huge plume of black smoke if it was an injector. If it's easy enough to plug the return line and build pressure you can possibly determine which it is. I would suspect the pump first.
