Rear Suspension...What to Install First
I have my rear suspension all taken apart on my 66 to replace with all new stuff. What I am wanting to know is, what order should I do for the install?
My plan of attack is to
1) Install New spring
2) Strut Rod Shaft and Strut Rod
3) Shocks
4) Torque Camber Bolts when on Ground
Let me know if this sounds like a good plan. I hope to start the process next week if weather cooperates. I also replacing everything on the front suspension and want to get input on my plan for that in another post.
Thanks in advance.
3) Shocks
Thanks in advance.
Received 1,859 Likes
Inner strut rod (cam bolt) attachments.
Trailing arm pivot bushing bolts.
Rear shock lower attachment.
All of these requirements are shown clearly in the Assembly Manual, and are essential for rubber bushing durability.
3) Shocks
Thanks in advance.
3) Shocks
Thanks in advance.
As for the updated order of my install:
1)Install strut rod shaft/shock attachment with strut rod (torque castle nut/install cotter pin)
2)Install strut rod carrier and strut rod/retainers (torque bolts to carrier only)
3)Install shocks (torque bolts)
4)Install spring to carrier and trailing arm
5)Torque spring carrier bolts, strut cam bolts when at ride height
Does this sound correct?
