63 Windshield
63 Windshield
Who sells the correct and best Windshield rubber gasket for a 63 SW. I also need 28 new clips. Are they original style and do all the vendors sell the same ones.
Received 6,940 Likes
2015 C2 of Year Finalist
Paragon has the right clips.
To my knowledge, the only company making Corvette windshield rubber, is Corvette Rubber. Most vendors carry the one from Corvette Rubber. If your not sure who's they are selling, ask.
I don't recall who makes the molding clips, but I'm pretty sure there is only one source for them also.
Are the ones from Paragon (the USA made kit) now the ones that will work correctly ? I remember over the last few years it seemed like none of the reproductions worked correctly. I'll be needed a set for my coupe as well.
https://www.paragoncorvette.com/p-35...kit-coupe.aspx
Ray
Ray
Ray
Ray
That is the reason that I asked the question. We seem to remember the same thing. I hope that someone can tell us for sure. I had to remove my 63 SW windshield to find a water leak. I am pleased that the windshield frame is in excellent shape and I found the water leak where a very small area of the roofline was unbonded right where it touches the windshield frame. I think that I will be good to go after a correct reinstall.
I hope that you make it for Keels and Wheels this year.
Jay
Ray
Ray
The US made 64-67 clips that Paragon has, I think are the updated clips, that are supposed to work. I'm pretty sure that Long Island is the company that is actually making the correct clips. I would check with Paragon (or anyone else you might buy them from) to make sure that they are the better clips.
Hello Ray,
Jay
Jay
I ordered my windshield rubber direct from Corvette Rubber. Not sure I'd trust a middle man to have them as the source. You have to be VERY cautious ordering the '63 window clips. I think there are at least two different types and they HAVE to be for a '63. Mine were back-ordered for quite a while but finally arrived. I'll try to find my invoices and post them here. You get the wrong thing and you're screwed.
This is what I found but IIRC there were two types of clips and I may have had to order them elsewhere...can't remember!
Jay
I did not replace my windshield (yet)....since I was replacing the headliner anyway and had all the metal trim out around the windshield I put sealant around the perimeter of the windshield gasket-to-frame area by lifting the gasket up carefully. I think that will prob solve my leak. If not I'll deal with the windshield later on; that's why I have the clips and gasket in my spares locker.
Here is what you need:
http://1963splitwindow.blogspot.com/...tion-1963.html
This article also states that Paragon may have the better fitting clips - so it might be "my bad" on that purchase.
We'll see... Note the number and types of clips shown - 30 on your car is too many it seems.
That answers all of my questions. I will get everything ready and do a trial fit of the clips and trim and then go for it.
Jay
If you can reciprocate by letting me know what molding tool you used to pull the windshield molding off I'd appreciate it. A picture or link to the product is fine.
I've never pulled molding off a vintage car and have NONE of the tools to do so.
It'd be nice to buy something knowing somebody else used it successfully for the same task on an SWC.
Jay
Well if you don't have a tool that you can share with me at least send your neighbor over for a day or two...
Jay
Yeah - Mike is my "back up plan" when I fall flat on more difficult tasks. Don't go to too much trouble posting pics or whatever. I'm prob gonna leave the windshield alone unless I have massive leaks that my Bubba caulking job missed...
