Startup Procedures after sitting for couple months
I have done some repairs to my 66 and now want to get it out in a week or two (once the weather cooperates) and make sure everything is good. What do I need to do special to start it up after sitting a couple of months? Thanks in advance.
John
John
Received 6,547 Likes
C2 of Year Finalist (track prepared) 2019
I agree with Jeff. Turn the key and go.
Jim
Jim
Enjoy while you can.
Received 2,703 Likes
Ohio Events Coordinator
C2 of Year Finalist (stock) 2019
St. Jude Donor '14-'15-'16-'17-‘18-'19-'20-'21-'22-'23-'24
I'm a firm believer in having oil on moving parts after draining away from sitting weeks on end. Someone posted a solution I use - crank a couple times first without setting the choke so it won't fire (plus fill the carb bowls). Then when you set the choke, there will be oil where it wasn't.
Two choices, both valid:
1. If it's your "baby", it's okay to "baby" it!
2. OTOH, it's well-proven, rugged, reliable '60s Chevy mechanicals, go ahead and crank it!
Like Steve, said, charge the battery.
I would also check the following...
coolant level
oil level
brake fluid level
BTW, what kind of repairs have you done? Anything fuel, electrical, etc. related?
May want to think about having a fire extinguisher closeby and might also want to think about moving it out of the garage before you start it.
Also, take a good look around, make sure mice haven't decided on a short term rental.
coolant level
oil level
brake fluid level
Thanks for the responses. I knew I didn't have to do anything with the C6s (other than keeping batteries charged) I have had, but this is the first time letting the 66 sit since I have had it.
If I crank it for a bit won't the carb fill with fuel instead of having to manually fill it?
coolant level
oil level
brake fluid level
coolant level
oil level
brake fluid level
Yes, it should fill the bowls in short order. Basically by filling them ahead of time, your cutting down on cranking time (battery life, starter life, etc). But as long as there is no blockage in the fuel lines, it shouldn't take much to turn it over.
You can fill the carb bowl by cranking the motor over a few times. That will also prime the oil system.
Let sit for 5 minutes, open hood and look for carb leaks.
Cars burn up from leaking carbs.
If no leaks, crank motor until starts.
Doug
Doug
I had leaks last summer from the end screws on the bowls loosening up. I am hoping I fixed that and it doesn't occur again
I don't like cranking on an engine that has been sitting. It circulates and builds oil pressure slowly. I like to prime the Holley until it just starts to dribble out of the idle ports and then hit the key so that if fires immediately and builds pressure fast. I guess other theories abound.
Whatever you do, Do Not let any old gasoline that has been sitting in the tank get into your carburetor. This Ethanol blended gasoline starts to degrade very quickly, is highly hydroscopic ( which means it sucks moisture out of the air) and will go through what is called Phase Separation. The ethanol and water will separate from the gasoline and settle on the bottom of the tank, the next stop is the fuel line. Gasoline cannot be reconstituted after it has gone through Phase Separation. It cannot be remixed.If you did not use fuel stabilizer before storage, drain that mess out and use fresh fuel. This ethanol is not as good as they would have us believe. Good luck!
