My 67 vette build
#41
I forgot to mention, I am trying to learn the history of the car, and possibly try to find that trim tag. The previous owner was a dealership, whom I contacted and they do not know any history of the vehicle, and claim they bought it in the same condition I received it, with no trim tag. The only other clues I have on the history is pictures from after the fire and before it was cleaned up. I also have a copy of the title before I transferred it into my name which shows the previous title number out of Michigan. The pictures are out of Michigan and the engine is a 427 tri-power, If anyone knows anyone in Michigan who had a 67 tri-power that caught on fire with in the last year or two please let me know.
#42
Received 6,940 Likes
2015 C2 of Year Finalist
The car had factory AC from the pictures
#43
thanks for all the support, im not in the market for a salvaged c2, the salvage car i plan on buying is a 4th gen camaro or firebird, or a C5 should be able to pick one up for around $500 and ill be using the ls1/t56, seats, seat belts and maybe a few other parts. Also this C2 is not a salvaged title, the title is clean despite the damage.
Again, no disrespect....I DO wish you luck with your build. I'm a cheap sob myself, so I can relate to 'budget builds'
#44
Theyre everywhere going between $25 to $1200 at the auctions. Ive been monitoring the auctions for a few months now
#45
I doubt you will find the trim tag, but you might find a replacement on ebay if you shop around long enough. I can"t imagine somebody bothering to take the Trim tag while leaving the VIN, but in your case, im glad they did.
#49
I'm thinking this was prob a rare option car, the tri-power was most likely original, the dealership who owned it last most likely parted out the expensive stuff like the engine and steering column and that trim tag, and the sell of the car itself was just a bonus.. and lying to me was prob easier than explaining that, but there's still that small chance of whoever owned it in michigan has the trim tag...like I said before, I'm not too woried about it, but it would be nice to have if I can track it down
#50
Trim tag wouldnt be worth too much...probably 800 bucks max. If it was actually a tri power car, they would have been much better off keeping the numbers matching block with the burnt chassis and VIN.
Doesn't really much matter now! All that matters currently is what you make of it! Hopefully the guy in NC has the fiberglass parts you are looking for and isnt asking a fortune for them!
#51
They might be closed down, I tried calling and they had a message saying they're closed today and 28th but doesn't say what month or year, and the email I sent them had a failed delivery
#53
C2 of Year Finalist (performance mods) 2019
I talked to Greg in Fl at the NCRS event. His truck blew a transmission on the way down. He does not have a secretary and he is terrible at keeping his messages up to date. Just keep trying. Give it a few days and if you can't contact, let me know.
#55
#56
John Z is the most knowledgeable person on this forum. He worked at GM and remembers every part and procedure used for building midyear Corvettes. You responded to him with an LOL in one of your initial posts.
#58
Do you have any body parts to start with? Or are you looking for a new body? Looks like there's part of bird cage sitting on the frame now.
My 63 roadster burned down to the ground, I used new replacement body panels on the original birdcage and have the car almost done now. I'm not even close to 100K into it even with the brand new LS3/T56, new everything and I live in Europe so you can double all the catalog prices for me.
Keep us updated, I always like these funky projects.
#59
How much did you spend for the LS3/T56? I think im going to spend a little more to go that route instead of an LS1.. I wanted to prove I could build this car for 25k, but I cant let me trying to prove something ruin the way I want to build my dream car.
#60
Was it a coupe on convertible? Zip, paragon, and others sell the rear lock pillars, luggage stop extensions, luggage stops, and the upper windshield piece you are missing.
If your car was a coupe, well, they don't make the pieces you need yet. I spoke to caledonia the other day and they are in the process of making the tooling to reproduce the coupe roof sections, but they aren't ready yet. No new Birdcages are available.
