How to Tell if SS Caliper Sleeves
Old 02-11-2014, 12:22 PM
JohnGibson
JohnGibson's Avatar
Default How to Tell if SS Caliper Sleeves
I had problems with my calipers leaking so I am rebuilding them. Currently have them apart and the pistons are out. How can I tell if they are SS sleeved? They don't look silver, but didn't know if they would change color with the fluid. Any pictures and/or advice would be appreciated. Thanks in advance.
John
Old 02-11-2014, 12:27 PM
MikeM
MikeM's Avatar
Received 1,843 Likes on 1,398 Posts
John
The sleeve is a very thin wall. You should be able to see a lip at the top of the piston bore. Also, if the bore is rusty or corroded or you can't wipe same out with a rag, you can bet that the calipers haven't been sleeved
Old 02-11-2014, 03:43 PM
JohnZ
Support Corvetteforum!
JohnZ's Avatar
Received 1,857 Likes on 1,100 Posts
If your caliper bores look like the photo below, with the cast-in piston guides in the bottom, and 1st-design pistons with guides, chances are they haven't been sleeved; the first thing the rebuilders do is to machine out the piston guides so they can use the 2nd-design pistons in everything.
Old 02-11-2014, 03:57 PM
JohnGibson
JohnGibson's Avatar
Thank you, sir. This helps a lot. From the pictures, mine have been sleeved then since bottom has been machined out.
Old 02-11-2014, 06:19 PM
oengus
oengus's Avatar
Touch the bores with a small magnet. Most all stainless alloys are non-magnetic.
Old 02-11-2014, 06:48 PM
65 Pro Vette
65 Pro Vette's Avatar
Received 1,046 Likes on 576 Posts
C2 of Year Finalist (appearance mods) 2019
Just because there is nothing on the bottom of your bore doesn't make them sleeved , you may have 2nd design calipers.
Old 02-11-2014, 07:22 PM
Thomas66
Thomas66's Avatar
Leaky brakes. fluid out, air in, was one of the most frustrating issues I had with my '65 in the late sixties. Each caliper received a honing and lip seals as required. Could there be a set of original calipers today that haven't been sleeved?
To How to Tell if SS Caliper Sleeves
Quick Reply: How to Tell if SS Caliper Sleeves
