Converting Caliper Lip Seals to O-rings
Old 01-20-2014, 07:52 PM
JohnGibson
JohnGibson's Avatar
Default Converting Caliper Lip Seals to O-rings
I am wanting to convert my calipers to O-rings from lip seals since they are leaking. When converting, do I need to buy new pistons or will my current ones work?
Old 01-20-2014, 09:49 PM
jrm5657
jrm5657's Avatar
2022 C2 of the Year Finalist - Modified
http://www.keenparts.com/pages/detai...partnum=500322
http://www.keenparts.com/pages/detai...partnum=500323
They come as a kit with the pistons. If your calipers are already sleeved, just pop these in for $80 and you will be all set.
Old 01-20-2014, 10:02 PM
wraplock
wraplock's Avatar
It is actually a very simple and straight forward install. The kit will come with easy to follow instructions. I found it much easier than replacing the lip seals. I already had swapped out my calipers for the Stainless steel ones from Vette Brakes so all I needed to do was clean them up a bit with some 2000 wet/dry sand paper with a little brake fluid. I then rinsed them out good, wet the bores and the o-rings with a bit of clean brake fluid and install.
Don
Old 01-21-2014, 06:44 AM
Chuck Gongloff
Support Corvetteforum!
Chuck Gongloff's Avatar
Fairly routine job.
Here are some pics I took when I did the calipers in my 69.
My kit came from Vette Brakes & Products.
Chuck
Old 01-21-2014, 10:11 AM
65silververt
65silververt's Avatar
Just be careful installing the lip seals. It's easy to screw them up if you tap too hard too soon.
Old 01-21-2014, 11:31 AM
JohnGibson
JohnGibson's Avatar
I have been unable to check today since too cold, but will the o-ring kits work with calipers that don't have ss sleeves installed? Not sure if mine have them or not.
Old 01-21-2014, 12:43 PM
stingrayl76
stingrayl76's Avatar
If your caliper bores aren't pitted and just required a light honing, you won't have to have them sleeved. The O-ring pistons and seals will work fine.
To Converting Caliper Lip Seals to O-rings
Quick Reply: Converting Caliper Lip Seals to O-rings
