64 rear blower cover ?
I purchased a new cardboard cover panel for the rear blower since my old cover was split. Upon removing the carpet from my old cover, I notice that the holes in the cover had what I think are rivet in the holes. The mounting screws goes through the rivets when you screw on the carpet/cover. My question: did these rivets goes through both the carpet and cardboard cover or were they only in the cardboard? Also were these rivets original to the car or added by a previous owner? Thanks.
Others will weigh in on the rivet issue I'm sure.
Dave Z
It not the ring around the screw head, these are still on my screws. The best way to describe these are a about a 1/4' long metal tube with the two ends flattened out to form rings. The flattened end towards the carpet side is a larger diameter then the other end which extended through the hole in the cardboard. Thinking back to when I removed them from the old cardboard, some of the carpet was pinched between the flattened end and the cardboard, so these must have been crimped the the carpet already glued to the cardboard. I guessing this isn't original?
Received 1,859 Likes
Those are called "eyelets" - also used on the kickpads and on '63-'64 door trim panels.
DZ
