Need to Remove Glue
Need to Remove Glue
Took up my front carpet,Bubba was in there and glued everything down.Have the carpet up and I'm scrapping the glue off the floor. Is there something I can spray on to dissolve the Glue so it scrapes off easily.
Paul
It needs removed because its probably keeping a lot of the foam backing stuff off the carpet stuck to the floor board ... went thru it in my '61. You just have to suck it up and scrape the snot out of everything. I use NO glue in my '61 when installing carpet not even one eyedropper's worth - not necessary whatsoever!
