Corvette rewire
Corvette rewire
Installing a new wiring harness as part of my 1960 restoration. Cannot get any interior lights including the the instrument cluster to turn on. Is there a trick I am missing. People tell me it's a grounding problem but everything checks out according to the wiring digram
I also have a copy of the wiring diagram from another member for a 60, send me an email if you need it and I will send it to you. dan@staff-tech.net
Make sure your wiring harness is plugged in securely to the switch. It might be easier to loosen and drop the switch, plug in the harness, and then reinstall the switch. It's tight up in there.
It only takes two things, 12v and a ground. You are either missing the 12v going into the switch, the switch isn't working, or the ground isn't connected to the negative battery post via the ground connections at the dash. The only other possibility is a broken wire interrupting the 12v or the ground. I'd ground any of the light bases to a known chassis ground. If that didn't get light, I'd jump 12v to any of the hot wires to any bulb. The easy way is to measure for 12v at any bulb with the black wire on the meter connected to a known good ground (negative post on the battery is the most dependable). If you don't have it there with the light switch turned on, measure on the output of the switch, if you don't have it there measure on the input of the switch, if you don't have it there, go to the source (fuse). You can go either way, but if you have 12v on the connection to the bulbs and no lights, the ground you're using isn't connected to the negative post on the battery. (via the metal parts of the dash, etc)
