C1 Side Mounts???
C1 Engine Side Mounts???
I can't be the only guy who ever has attempted this and I imagine the answer is right in front of my face but I just haven't seen it (please don't beat me up too bad). I have a good C1 frame that I don't want to get rid of; so can anyone tell me where I can go to get the details on where to weld the engine side mounts for an LS motor into this frame? Also, any suggestions on sources for the side mounts would be appreciated. Thanks, qrance
Received 2,134 Likes
I think the lack of response to your question is the title. I and some others my mistake it for someone wanting to put side exhaust on a C-1. I had to read it a couple of times for clarity. The thought and sight of side exhaust doesn't have much eye appeal. Dennis
2021 C1 of the Year Finalist - Modified
To each his own, Dennis ! I would like to find header side mounts for my 60. However I also put flames on the side of my car which would horrify some on this board. As far as the side mounts for an LS1 , I would contact some of the frame builders that are being used, also look on eBay. They are putting these engines in a lot of stuff now. I myself would set the engine/trans in the frame where I want it and start fabbing up parts. Pops
Former Vendor
Billy Dawson (Corvette Correction) is in Seguin.
Look him up, he'll set you up. His number is 830 305 7496
G.
Yes, I am Billy's neighbor and will eventually go with a Dawson frame. But I have to do this in small stages due to cost. His frame is an awesome frame and due will need to be the last thing I switch over. This will give us time to build up the frame fund, but still be able to take the Vette out for a drive occasionally.
Installing side mounts will make replacing the original steering an absolute necessity. The side mounts and the existing steering, both want to occupy the same real estate! You will need to switch to a R&P unit.
Regards, John McGraw
Clarification: Engine Side Mounts
Sorry, I wasn't very clear in the original post. I am wondering if there is some sort of known place/mark (or anything) on the inner frame rails that I could use as a reference point for welding SIDE MOUNT engine mounts onto the frame? Yes, the original steering box has been long removed and replaced with a Speed Direct Steeroids R&P system that is really nice (so there won't be any obstructions). So I am beginning to gather that the best way to determine where to weld the side mounts to the frame is: mock up the engine, lower it into the engine bay, connect it to the automatic transmission (but leave it on the hoist), observe and mark the frame where the engine mounts line up with the frame, remove engine, weld in the side mounts and reinstall the engine? Is this more or less the best way to do the job? Again, thanks for everyone's help.
LS engine mounts
don
St. Jude Donor '07
Bill
