1961 Dual-Point Distributor Lubrication
Old 10-30-2013, 12:04 PM
johngammel
Support Corvetteforum!
johngammel's Avatar
2017 C4 of the Year Finalist
Default 1961 Dual-Point Distributor Lubrication
What is the best specific lubrication procedure for the internals of this distributor (a 270 HP 2x4)?
Old 10-30-2013, 12:07 PM
ohiovet
ohiovet's Avatar
2016 C1 of Year Finalist
I believe the only lubrication required is on the cam.
There is usually a felt wick to which a drop or 2 of oil is all that is required.
Old 10-30-2013, 03:50 PM
Frankie the Fink
Frankie the Fink's Avatar
Received 7,082 Likes on 4,736 Posts
Army
The external oil tube on stock distributors provides 'internal' lubrication and requires a few drops of motor oil every 5,000 miles according to the ST-12.
Old 10-30-2013, 05:04 PM
TCracingCA
TCracingCA's Avatar
Received 1,683 Likes on 1,005 Posts
Default I like!
A little dieelectric grease from the electronic supply store (non conductive) I also have some in my plug boots!!!!!! Or the Volkswagen guys with selling a little OO9 mechanical advance distributor sell a little grease packet for that purpose. I got rid of things that ride on lobes, except for the cam!!!!! Thus I have magnetic pickups on my stuff!!!!!! I haven't had to grease that up anymore!
Yes I know what you are talking about!!!!!!!!!! Hope that helps!!!!!!!
Old 10-30-2013, 09:13 PM
JohnZ
JohnZ's Avatar
Received 1,858 Likes on 1,101 Posts
The oiler tube with the GITS cap in Frankie's photo in post #3 lubricates the upper mainshaft bushing - there's a tubular wick extending from the bottom of that tube that puts oil on the bushing. Lubrication of the points is a drop or two of distributor cam grease when you change the points or set the dwell.
Old 10-30-2013, 09:32 PM
TCracingCA
TCracingCA's Avatar
Default John Z, you are truly awesome, except when
you pick on me about the fabled 450 hp 427. You have a working tech encyclopedia brain!!! And I mean that as a compliment!!!!!
To 1961 Dual-Point Distributor Lubrication
Quick Reply: 1961 Dual-Point Distributor Lubrication
