1960 clutch pedal rod question
The clutch pedal rod has a seal and a seal retainer that screw into the firewall. Do they screw in from the engine side of the firewall or from the clutch pedal side? I have seen it both ways in different catalogs and this page on my assembly manual is not legible. Also, does the hole in the seal/retainer run horizontally or vertically? Again, I have seen it both ways, but vertically seems to make more sense. Thanks.
But it appears to be dependent upon the year, which is probably why the catalogs show it different ways.
A good recent discussion is here
http://forums.corvetteforum.com/c1-a...-firewall.html
