61 Genrator
Old 10-18-2013, 08:56 PM
6vette1
6vette1's Avatar
Cranes Corvette has the correct generator for $309. I just need to know if I need to replace my existing pulley. Please see photos. Thanks
Old 10-18-2013, 09:24 PM
rich5962
rich5962's Avatar
It appears to have the space (1/4") to the fan, and if the pulley OD is 3 5/8" and belt width is 1/2", then it's correct for a 58-62 Corvette.
Rich
Old 10-18-2013, 10:18 PM
6vette1
6vette1's Avatar
Those are the dimensions of my pulley and fan
Old 10-21-2013, 03:25 PM
6vette1
6vette1's Avatar
Looks like my generator has the correct end cap.
Old 03-16-2014, 10:52 AM
Big Alvie
1st Gear
Big Alvie's Avatar
I have a 1961 2x4 with generator #1102041. Is this right? The amp gauge pegs out high when rpms go up. What should I look for to solve this.
Old 03-16-2014, 11:31 AM
Frankie the Fink
Frankie the Fink's Avatar
Received 7,082 Likes on 4,736 Posts
Army
That generator pictured does have the right end cap and not the passenger car version...good for you.
Big Alvie - you may have a voltage regulator that has gone bad....measure across your battery terminals with the engine at about 2000-2500 RPM...if the voltage is much over 14.2V you need to jump on the issue quickly or wiring/component damage will result.
The '61 Passenger Car Manual has more extensive tests to isolate the exact problem.
Quick Reply: 61 Genrator
