C2 Panel contamination and repair
Those who have it, know what it is - those that don't, be grateful.
I've tried wipping the area off with acetone and then wiping with a dry cloth but to no avail - I've done this for the past 3 years. I'm now reskinning with West epoxy and resin - 4 layers on the top and 3 on the sides. I need to do the total left side top surround and the cowl.
That seems like it’s going to be an awful amount of surface finish work. From your post, I’m not sure what got on it. Has the hood surround been changed in the past and is something leeching through the paint?
I think in the end it would be easier and faster to replace the hood surround. I'm interested to know how you’re going to compensate for panel height alignment. I know real ’67 hood surrounds are hard to find but they do come up from time to time. If you don’t want to go aftermarket, the GM SMC panels can still be found also. You are much more brave than I am to attempt this.
Brake fluid
About 90%+ done in covering the Fiberglass repaired area with Vette Panel Adhesive – will finish up next year starting with GelCoat. This procedure should work and hopefully saved me from a new panel replacement and the fitting work involved with that – not that this repair wasn’t exactly a snap.
Could have been caused by a few reasons. I've owned the car since 1975 and I know that I didn't spill brake fluid on the panels. 40+ year old panels are subject to leaching from ANY contaminent found UNDER the hood -like brake fluid vapors or oil droplet vapors from the exhaust manifold or blow by from the tube going into the air cleaner (etc.). Fiberglass is porous and will suck up this stuff like a sponge and one theory is that the way vapors are routed from the fan under the hood are to the left side - to each his own about the reason.
Did you ever try stripping it to bare glass and shooting some good quality epoxy primer on it? I've done it that way and never had any future problems. Epoxy will seal whatever is in the glass from coming up through the paint.
If that fender peak line is straight and true side to side and up and down, you are a better man than I am. If it were mine and there was any wiggle or dip at all in it, which may not show up until final paint is there, oh boy that would not set well with me at all. If it is laser straight, and you got the heights right, you did one hell of a slick job on that one...
My own guess is that it is something in the original materials that is deteriorating and leaching to the surface.
Some also say I could have directly GelCoated the panel. I didn't want to chance it and think the West Epoxy resin/matte way was a better option.
That end section (up toward the headlights & bumper) I only laid 1 layer of fiberglass matte - it was not a contaminated area but I laid the matte so there was not a big drop off in contour since it was next to a 2 layer of matte. The 2 layer on the side butted against a 3 layer. The worst area on the top I did with 4 layers (2-14" sections), then going with a 2 layer then a 1 layer. Those aren't (exactly) pinholes but actually the one layer which I didn't completely block out. All is covered with (more than) a few layers of Vette Panel Adhesive which I individually blocked out. Here's the final which will get covered with about 6 coats of Gel Coat next season.
Front end and other areas look GREAT. Now it is time for the gelcoat when the temps get warmer for you. Or are you planning on getting it gelcoated before winter totally sets in.
DUB
DUB
My experience has been to heat the contaminated area with a heat gun or lamp, wipe with acetone then let it dry Repeat this process several times over the period of several weeks. This will draw the contaminants out of the glass. Then sand gelcoat sand and repaint. I would be worried that a fiberglass repair, especially in the top surround area will come back to haunt you. JMO
