new carpet, no insulation...
Got new carpet for my 65 Coupe from ACC and got it installed by a local upholstery shop.
I think I learned my lesson and will not cut corners and go the cheap route next time...
They did a very lame job! Car was filthy in and out, somewhat poor fitment of the new carpet, a few dings/scratches on the central console. Some of the interior panels not refitted properly and, most of all, they did not replace the insulation!! They put new padding but removed the insulation!! Not sure they could have kept the original insulation but at least they should have let me know before putting the new carpet w/o it!!! It was to be a $380 job, but needless to say I did not give them a penny for that lousy job!
Anyway, do you think I shall add the insulation (meaning I would have to remove carpet again and probably replace padding too). I drove it a few times and could not really feel a difference in term of noise or heat...
Thanks,
-Matt
Thanks,
-Matt
If you plan on driving it i would.. Mine use to get so hot it felt like you toes where on fire.
What i did was simple to be honest.. took out the seats, pulled out the carpet, went to home depot and got rolls of the thick insulation in the heat and air section. ( stuff you would see in your house, sorta looks like chome) put that down, also went up the fire wall as far as i can. Then bolted everything back in. i didnt do any testing before and after, but i can tell you my feet dont feel like they are on fire. This was a few years ago so im not sure what i cost now, But i think i spend like $60.00?
they replaced the carpet jute but not the insulation:
I mean this insulation
http://www.ecklerscorvette.com/corve...Product_Viewed
Jim
I could be wrong, but I believe all that was there from the factory was the jute padding. The Eckler's kit you reference is an add-on, not factory original. I didn't find anything but jute when I redid my '66 coupe. I added Dynamat throughout.
Received 2,127 Likes
Do you know if the carpet that was in your car was original or a combination of someone's creativity? Your description (two layers of something) makes me think it was someone's creativity. As far as I know all orig carpet was backed by jute padding only. Call it insulation, sound deadening, padding, but it was one layer of material. Most of us long term owners call it "jute" padding. The shop got it right. Not sure what your interpretation of "insulation" is, but put it in if you like. Dennis
Corvettes 63-67 had no insulation. 63/64 had foam backing on the carpet, 65/67 had jute. If they added jute that's all it should have gotten unless otherwise specified. You can't have both jute and insulation otherwise your carpet would be too thick. As suggested you might add some sort of heat barrier product like Dynamat under it all.
Sounds like the carpet may need to come out.
When I recently did my 67 coupe, I pulled the jute underlayment I discovered that it was original Stevens padding with a rubberized backing dated two months before my cars assembly date. I installed new rubberized jute padding over the foil backed heat insulation that's only about 3/8" thick and doesn't affect the ACC carpet installation at all.
Got everything from the 20% off sale at Willcox. Anyone who can use scissors, a Phillips screwdriver and a couple of scrapers can change carpet/insulation in their mid year car. Simple.
Tom
Tom
"I used hush mat and Jute material, well worth it."
Same here. I also included sound deadner inside the doors as well. It's amazing the results sound deadner makes inside the cabin.
