vin number problem
vin number problem
I have what i think is a 1967 corvette that is suppose to have a 427 435 hp in it an im being told i have the wrong block an heads for it can some one please help me with this the block and head number.
The vin on my car is 194677S106615
the block I have is 3904351
and the heads i have 3904391 with early date codes
im being told this car was built an left the line dec 23 1966 if this is true then what block and head am I supose to have
please help I have alot of money wrapped up in this thing an nothin to do with it
2023 C1 of the Year Finalist - Modified
2022 C1 of the Year Finalist - Modified
2020 C1 of the Year Finalist - Modified
2019 C1 of Year Finalist (performance mods)
2018 C1 of Year Finalist
The block is correct for a 67 bb. Your vin number that you listed would be stamped on the passenger side of the block just below the head with build date and suffix. The vin on the engine pad would look like 7106615
Received 1,857 Likes
Post some pics of the stamping so we can check the braoch marks, build date and suffix to see if it is 435 car. Do you know if the tank sticker is still on the tank?
problem is the original block wasnt in the car when i got the car and i got the block but has no stamping date on it was ground off but the casting number is there
how can i find out if this car was built in dec of 1966 off that vin number is kinda all i need to find out.
what numbers are suppose to be on the block and heads
where do i find out about this stuff
Received 1,046 Likes
C2 of Year Finalist (appearance mods) 2019
What makes you think it was a big block car from the factory? Do you have the build sheet from the gas tank? I would bet 50% of the 67 big blocks are clones. The dates on the heads are under the valve covers and the date on the block is under the block near the pass motor mount.
KC
What is the cast date of the block? Because the vin derivative is not on the pad, and whatever was there is gone, the source is unknown. It could be the original, or not. You'll never know.
There is a 3 or 4 character code on the right side of the block above and forward of where the starter is mounted. It is upside down when installed. If it precedes the build date of the car then it's a good candidate. If it's after the car build date then it is not a good candidate.
e.g.
J306 - Oct30, 1966
L246 - Dec 24, 1966
B117 Feb 11, 1967
e.g.
J306 - Oct30, 1966
L246 - Dec 24, 1966
B117 Feb 11, 1967
