How difficult is it to install power windows in a 62 with manual windows
IS it very hard to install power windows in a manual car. Do they make complete kits that include everything you would need. Are there limited switches that stop the window at the top and bottom or does just hitting the bumpers cause window to stop. Anyone install windows and who did you purchase from, thanks
You might want to get a '62 Corvette Assembly Manual. I have an older version by T Michaelis Products that shows three pages of assembly instructions used by the factory to install power windows. The assembly shows part numbers for the motors, switches, retainers, trim panels, wiring locations and routing. It looks fairly complicated, but you should try to find this manual. Good luck.
There are two basic kits and which one you choose will depend on how original looking you want things to be. SPW (Specialty Power Windows) is one http://spwkits.clickforward.com/products.php and Auto City Glass is the other http://www.autocityclassic.com/index...d=90&Itemid=45 .
The Auto City has motors and switches and hooks up identically to the original power windows - including correct looking conduit. The SPW kit (which I used) works fine but does NOT use the direct drive motors as original and the windows operate faster than the original power windows. You CAN make them look original by installing polarity reversing relays and original style switches (a LOT of trouble). The kits are not cheap and then there is the issue of door panels; you will have to get new door panels withOUT the window crank handle.
There is a support in the door that may require you to grind a bit to pass the new regulator in (regulator installation is the worst part of the job). Sometimes you are lucky and no grinding required. The electrical hook up is straightforward. The SPW kit had fugly looking chrome tubing for the electrical conduits so I got original conduits and did the necessary mods to the doors and jamb to make them work. You can also make the SPW switches work with your EXISTING door panels and save big bucks by modifying the window crank holes slightly. That is what I did; a few pics follow. The last picture shows how critical the original conduit location is. Every time the door closes the metal conduit must "thread the needle" through two passages in the door jamb. It's fun getting that exactly right - if you decide to do that get in touch with me and I can give you the measurements for cutting the holes in the door and in the jamb.
If I had it to do over again I would have gone with the Auto City product for the "closer to original" factor.
Yes, I took a 'flyer' and modded the existing manual window panels and it worked out nicely. I did have to grind about 1/8" out of the driver side door crank hole to get the double switch in but that was no biggee.
thanks
Thanks, I've got a better idea now of what will need to be done.
