T5 5 Speed Install . . . DONE!!!
Received 1,962 Likes
After 3 years of planning and acquiring parts, I began what I thought would be the simple install of my GM WC T5 in my "66 L79 convertible in the fall of 2011. While the install went rather smoothly, upon completion I had 2 major issues I wasn't expecting . . . severe clutch chatter and an annoying vibration above 1800 rpm's. The task to fix both issues wasn't easy - and all of my efforts were interrupted by an extensive home remodeling project, lack of time, and other "life" issue that got in the way. I've tried several things over the past 2 years,but couldn't seem to solve the 2 major issues easily.
About 60 days ago I got serious about getting this install completed, and pulled the engine/T5 for @ the 6th time in the past 2 years. It turns out the vibration was caused by an improperly balanced pressure plate, and the clutch chatter was caused by a clutch disc with the wrong size "hub" . . . both parts supplied by a major powertrain company. Both parts were junk!!! I put my original pressure plate back in, along with a new Hays clutch - and my issues are gone!!! I've driven my car now for the past 2 weeks and I couldn't be more thrilled with the results . . . all the heartache has been worth it in the end. The shifts are short and precise, and the car runs great!!!
- total price of this conversion . . . @ $1200
- smile on my face as I cruise down the highway @ 2200 rpm's @ 60 mph . . . priceless!!!
Here's my original install post from December, 2011 with details and photos:
http://forums.corvetteforum.com/c1-a...n-my-66-a.html
Tom
Tom
Received 2,126 Likes
ok, lets hit the road! Dennis
Dennis,
I'm thinking about it! But . . . my brother is on a sail boat trip - delivering a sail boat from Annapolis to Myrtle Beach. I'll check to see when he gets back . . . there's still time!!! I need to come see you real soon and let you drive it!!!
Tom
Tom
Good idea! Check your PM. Dennis
Congrats Tom. That feeling of "SUCCESS" is something we need to feel more from life. I spent last evening installing a Pertronix unit in my 64. I usually don't have good luck on do it yourself projects but somehow I keep pushing myself in to the next one.
After several hours and even a posting here in the forum asking a question, a member's post allowed me to go forward and as they say: TUH-DUH!!!!!! When I hit the key and it started I think I felt a little bit of heaven.
I'm in no way comparing a tranny swap with an ignition upgrade. It's the feeling of "FINALLY".........that's the payoff.
I went for a moonlit drive last night to enjoy my success. I think I passed you on the road. You were the guy driving that had that HUGE GRIN on his face..............congrats. AZ
Thanks AZ! I've been working on the install off-and-on for the better part of the past 2 years . . . lots of things got in the way! Had the engine/T5 out no less than 6 times to chase several issues. My buddies thought I was nuts . . . but I was determined to make this swap work . . . and my perserverence finally paid off. Now I can really enjoy it! Next project - install cruise!
Congrats on your successful project as well.
Tom
Tom
Remember that famous saying Tom:
SUCCESS HAS MANY FATHERS!
FAILURE IS AN OPHAN...................
Burma Shave.
Burma Shave.
Did you end up using the factory shifter or upgrade to aftermarket?
I used the factory shifter - modified! The T5 is @ 2 inches longer then the Muncie, so you need to move the shifter @ 2 inches forward. Here's a photo of the modified shifter:
Here's of photo of the final version in the car:
Tom
It's good to hear this project has seen its completion! I'm sure that fifth gear is quite nice. Speaking of such things, have you had the opportunity to get the car on the open highway and test out the overdrive? If so, what kind of rpms are you turning at say, 70 mph? Do you know your differential gear ratio?
I've been searching for a WC V8 T5 for about 2 years now with no luck. If I do run across one it's very pricey.
Yes . . . 4.11 . . . the whole reason for doing the 5 speed!!! 70 mph is @ 2580 rpm's . . .
There's a guy in Florida working on a T5 conversion for his C2 . . . he's collected 3 T5's in the past year . . . let me check with him to see if he might be willing to sell one of them!
Tom
Great pictures. Definitely something I want to try. Did the gentleman ever contact you back about the three transmission he had? I am in Florida also and would not mind buying one if he had one. Thanks Sam
No . . . but I still have his email address and I'll send you a PM with his info. He is a "Forum" member!
Tom
Your posts on this helped me very much, Thank you! I did the same thing on my LS3 install. I sent the one we had to a place called G-force to get it beefed up. I love how it shifts (shifts like butter), it fits very nice, and no vibrations! Enjoy yours and Thank you again for the write up!
Gathering Parts But Close!!!!
I am still gathering parts! But I'm close!
I found a WC T5 and an 83 Camaro bell housing fairly close to my house!
Thanks to forum members pointing me in the right direction! I am in "while I have the engine out" planning mode now. Just gathering small stuff now to fix it all while its a part.
Thanks for the great Thread!!
Cruising
Hello Everyone,
1st of all I would like to thank everyone who has contributed to this topic discussion, current post and related. I do not believe I would have ever considered the install if I had not stumbled across these posts.
I am currently in the process of rebuilding a recently purchased 89 WC T5 out of a Firebird for install into my 66 L79 vert. I am planning the install in a few weeks pending resolution/answers to a few questions.
Although the information contained is very detailed, and appears to cover most popular applications, I am still unclear on a few points.
1) What bell housing options are available and recommended. If possible, I would like to retain the mechanical clutch set up. Assuming this configuration, can a hydraulic bell hsg. be used with modification to the fork, or is the rare mechanical housing the only option when using mech clutch.
2) I am currently running the stock M20, with a fairly new (15K miles) Hays clutch and pressure plate. Will this setup work with the T5, require new pressure plate to mate with T5 input shaft, or is it recommended to go new with dedicated setup?
3) Using the angled Chevy housing, chosen for preferred shifter location, what is the best or suggested transmission mount option?
Tom, I really like the simplicity of your modified mount. Do you have any drawings or illustrations showing how the modifications were made, and do you have any information on the elastomer/rubber isolator used?
Thank you all in advance for any information and direction you can provide.
Don
Don
T5 Install
I believe someone on here has used the Hydraulic clutch bell housing with a manual clutch.They said you could even leave the bracket if you wanted to.
As for your Clutch/Pressure plate. You will need to buy a clutch with splines to match the T5.
Tom will Probably chime in here on #3. He is working on a Trans mount process that does not require cutting your existing trans mount.
You didn't ask about it but I will share my experience with the T5 rebuild. I am putting mine together right now! I just stopped for lunch and saw your post. Bob Hanlon from Hanlon Motorsports has been a great help to me! I first purchased the "How to rebuild a T5" video" Very helpful! When I was ready to start, he had a great price on a VERY complete rebuild kit. Then his wife also helped me thru the process of determining I needed to replace 2nd gear. They are both very Knowledgable and a pleasure to deal with! I am almost back together with it.
Good luck!
This is a great Thread!
Good luck!
Hello Everyone,
Don
Don
