Seat Removal Question
Old 09-14-2013, 06:30 PM
Jukedog64
Jukedog64's Avatar
Default Seat Removal Question
OK this may sound dumb, but how do i get the drivers seat out? I can see the two hex bolts at the front of the seat rail but where are the rear ones? Here's my problem, the seat back pivot bolt closest to arm rest pad came out. I can't get it to start back in the seat frame. Is there a trick? Arm rest pad is in the way. I figure easiest was to take the seat all the way out so i could get at it without fighting it...
Old 09-14-2013, 06:55 PM
RJ1
RJ1's Avatar
There are no rear bolts. The rear is held with 2 fittings that the seat rail slides into then it is bolted down with the 2 front bolts you see. Take bolts out pull the seat toward front of car. You don't mention your car's year mine is a 65 so better check to assure this wasn't different for your year.
Old 09-14-2013, 07:32 PM
Jukedog64
Jukedog64's Avatar
Thanks for info.. Thats easier than i thought then. BTW mine is a 64 Coupe. I havent figured out how to add my vehicles pic here yet..
To Seat Removal Question
Quick Reply: Seat Removal Question
