C1 watch repair
C1 watch repair
Hi all,
I'm trying to refurbish the watch, which is original to the car and dated feb 60, and I can't remove the setting button from its shaft in order to pull out the glass and face.
I made a search, (I promise), but found nothing
Any idea how to do this ?
Thanks, Claude
Thanks, Claude
The **** unscrews off of the shaft.
Try some penetrating oil where the shaft goes into the ****. Hold the shaft with a pair of needle nose pliers and turn the ****. Depending how frozen they are you might need a pair of pliers on the **** and the shaft.
