Herky Jerky Accel Pedal, what is wrong?
Gracious Guru's of the CF.
I've had the chance to drive two other C-2's now (65 and 63) and WOW, man do I have a long way to go to refine my car.
On the others (very nicely restored) the accelerator pedal was nice and smooth where as mine is herky jerky while in gear.
Overall I would say that the pedal is too stiff.
I took the spring off and the actual mechanism and movement of the pedal and other related parts is silky smooth.
So it must be with the spring I have. I looked in my AIM and Noland Adams book and neither provide detailed specs on the spring.
See pics below for how this was set up when I bought the car. The spring that is on there is 9/16 OD and is 1 5/8" long (just the coil part when not pulled)
Any ideas?
thanks so much
PS. I also noticed in the AIM that it shows a cotter pin in the actual rod where as I have just the spring going through the rod hole to hold it in the bushing of the throttle lever on the carb? If I should have the CP then do I just hook the spring on the other side?
Any ideas?
thanks so much
2021 C1 of the Year Finalist - Modified
I feel you are better off (and some racing sanctions require it) to run 2 lighter springs instead of 1 heavy one. One inside the other IIRC GM used to do this .
I'll be damned you are right. The back side of petal has a piece of white plastic and there is a pretty good divot worn in it.
I also noticed while reading the AIM instructions for setting wide open throttle that my swivel where it connects the rod and lever is not correct.
Boy, the time it takes to undo half a**ed fixes of the past and worn out parts. But I'm learning
thanks so much
thanks so much
Hey;
does not look like I have the right spring as well.
Paragon shows a different one
https://www.paragoncorvette.com/p-35...rn-spring.aspx
Also, my rod to lever connection is not right at all
https://www.paragoncorvette.com/p-35...ation-kit.aspx
PS. what is the spring set up on the pic below?? It looks like the two spring set up that was mentioned above.
Received 1,844 Likes
Make sure your rear linkage swivel isn't catching on the ignition shield with the spring on. Yours may be on backwards.
Can't really tell if you have the wrong spring but it looks like it might have too much tension.
There were assorted different accelerator return springs, used between 63 and 67. The spring used varied by year, small block or big block and the type of induction system. The spring you have, doesn't look like any of the springs, originally used between 63 & 67.
62-63 340's, used the white spring, that's in the Paragon link. I would order the correct spring, the rod bushing kit, and the accelerator pedal "anti-squeak" pad, or a whole pedal if you can't locate the pad separately. With all of these installed, you should find the movement of your accelerator linkage, much smoother.
It probably wouldn't hurt to find a smaller, lighter spring, that would fit inside the correct white one, just for safeties sake. I can attest to the fact, that it's quite startling, to have a return spring break!
I hope this does not confuse things. I have an unmolested '63 340.
The top spring in the photo is my original part.
The lower one is the reproduction I purchased from Paragon.
The coiled portion was too long so I had to cut the length and bend it to work.
(long story, but I reinstalled my original)
Bottom line is, I do not think the reproduction springs are correct.
Rich;
thanks for the post. Here is a pic of the #754 spring from Paragon site.
It looks similar to your original.
PS. Look at Noland Adams book Page 128-130. There are pics of the same spring
Received 4,583 Likes
C1 of Year Finalist (appearance mods) 2019
there should be a hole in the carb linkage arm specific for the spring. It doesn't go where the cotter pin goes to hole the rod on. It may be binding with the wrong angle like that, giving that not very smooth feel.
The bottom spring in my photo is #754 that I purchased from Paragon.
The coiled section was too long. If you look closely, I had to cut the long straight "leg" and bend a new hook into it to make it work.
Maybe you will have better luck with the reproduction part than I did
Rich
Received 1,859 Likes
Most later cars used the other arrangement, with the return spring "hook" through the hole in the accelerator rod, but '63 was different (as usual).
For Don's '63, it takes a separate cotter pin for that application, but the carburetor throttle arm in his photo is missing the separate small hole for the spring. The '63 A.I.M. shows this in UPC 6, sheet C1.00, View "A".
Rich, do you have this hole in your arm that John Z speaks of??? Can you take a pic?
John Z; thanks for the post. You are correct and see below the page you reference. I wonder why in the world I'm missing a hole in the throttle arm for the spring???? I guess a lot can happen in 50 years
I don't think it would matter much where the spring was hooked, the OP's spring just looks too strong.
Jim
