Go Back   Corvette Forum > C1 & C2 Corvettes, 1953 - 1967 > C1 & C2 Corvettes
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C1 & C2 Corvettes
General C1 Corvette & C2 Corvette Discussion, Technical Info, Performance Upgrades, Project Builds, Restorations Sponsored by
Flaming River
Industries
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 09-01-2013, 02:37 AM   #1
raytex
CF Senior Member
raytex's Avatar
Default Which fanblade should I use on 396/AC
My 65 car was original a 327 with factory air.
The 327 engine has been replaced with a 396 (Chevelle) in the mid 80s.
Which fanblade should I use not to have "heating" issues?
When I bought the car it was overheating, the previous owner installed a electric pull fan. This was with a 327 support, shroud and radiator.
I have removed the electric fan and installed a 396 shroud, radiator support (added the AC holes) and a BB aluminum radiator with a new AC condensor.
Should I use a 396 5 blade 17" or a 64-65 18" 7 blade or maybe a 66-67 18" 5 blade?
please advise
Ray
raytex is offline   Reply With Quote
Old 09-01-2013, 09:22 AM   #2
stingrayl76
CF Senior Member
stingrayl76's Avatar
please advise
Ray
I'm no expert but since you are using the 396 fan shroud, I would normally say to use the 396 5 blade fan. However, considering the added A/C you are going to need as much airflow as possible so you will need to determine which fan moves the most air and will clear the shroud. Hopefully someone can chime in ad provide the airflow information.
stingrayl76 is offline   Reply With Quote
Old 09-01-2013, 02:57 PM   #3
JohnZ
CF Senior Member
Support Corvetteforum!
Frequently, the fan used with A/C has deeper pitch (blade angle) than a non-A/C fan; although it may have the same number of blades, it will move a lot more air.
I'm not familiar with the 396 shroud/fan sizing, as that combination never had A/C - maybe one of the 396 guys will chime in with alternatives.
JohnZ is offline   Reply With Quote
Old 09-01-2013, 04:49 PM   #4
TheSaint
CF Senior Member
TheSaint's Avatar
Since it is a AC car it just as likely that it had a 7 blade fan according to the Vette Vues Fact Book
Well, i must say that the book have been wrong before..
TheSaint is offline   Reply With Quote
Old 09-01-2013, 07:28 PM   #5
avideo
CF Senior Member
avideo's Avatar
Default You might want to consider a 17 or 18 Inch...
Seven Blade Flex fan to pull the maximum air through you radiator. Whatever is the largest size your radiator shroud will allow.
avideo is offline   Reply With Quote
Old 09-02-2013, 07:04 AM   #6
raytex
CF Senior Member
raytex's Avatar
Quote:
Ok thx I will just do that and meassure the fanshroud and see what is acceptable.
Old 09-02-2013, 07:09 AM   #7
raytex
CF Senior Member
raytex's Avatar
Of course it had a 7 blade , 34.5 degree pitch fan blade with the original shroud. When I got the car there was a plastic fan blade installed.
Now it has a 396 shroud, I will measure the max possible and either get a 64-65 18" 7 blade 34.5 degree pitch or the 396 17" 5 blade which also has a 34.5 if I understood correctly.
Clearnce fan blade to shroud should be how much?
1/2 inch?
Ray
Old 09-02-2013, 09:27 AM   #8
67vetteal
CF Senior Member
67vetteal's Avatar
A 1/2" should do it. Any closer and your running the chance of it touching when you throw a few Hard Shifts! Our engine mounts do get softer through the years and allow the engine to rotate a little bit under strong acceleration. Al W.
67vetteal is offline   Reply With Quote
Old 09-05-2013, 05:07 PM   #9
TheSaint
CF Senior Member
TheSaint's Avatar
After what i have read it is not all "off course" factory AC cars had 7 blade fans.
Factory AC cars was delivered with a 5 blade fan because if they was out of 7 blade fans they installed 5 blade fans
That is what i read
1/2 inch?
Ray
Old 09-05-2013, 05:14 PM   #10
midyear
CF Senior Member
midyear's Avatar
I ran a 74-75 7 blade fan (notched blade) and heavy duty clutch on my 67 427 air car for years with out overheating issues, its been what I used on other big block cars to help them cool better as well. may not look right, but did the job.
midyear is offline   Reply With Quote
Old 09-06-2013, 12:04 PM   #11
raytex
CF Senior Member
raytex's Avatar
That is what i read
Then my problem is solved.
But why would they do that?
5 blade 24.5 degree pitch or 7 blade 34.5 degree pitch.
If GM does make an issue about the number of blades and the pitch degree of the fan
Guess any fan will do then.
Old 09-07-2013, 04:28 PM   #12
TheSaint
CF Senior Member
TheSaint's Avatar
I think it was Noland Adams Volume 2 i read that they used 5 bladed fans if they did not have the correct 7 blades at hand
Reload this Page Which fanblade should I use on 396/AC
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
