Someone educate me on the value of C2's
Add another couple hundred for fees/taxes/etc. . .
Is this really worth $5k+?
http://www.copart.com/c2/car_auction...SEARCH_RESULTS
Current Bid: $4,550 USD
No. The only thing you are buying is a block and a vin plate. If they aren't warped or melted.
Since it's a BB. It may turn up at Barrett-Jackson in a yr or two as an original survivor.
Wow - hot enough to melt the instrument panel die-cast.
[QUOTE=RandomTask;1584783057]Add another couple hundred for fees/taxes/etc. . .
Beware of phantom bidders on Copart!
2018 C2 of Year Finalist
St. Jude Donor '12-'13-'14-'15, '19
As a charter member of National Corvette Immolation Society (NCIS), I can say that 1966 incinerated hulks aren't quite as desirable as 67's. I think that car is a tad high at $4,550, even though it is a finely charred example.
It should be noted, and is recognized in the NCIS judging manual, that firewall char with characteristic blackish-streaked gray fibers is almost certainly NOS char, and hence this particular hulk can be higher valued
Excellent analysis. There's also a '67 BB car that has also been thoroughly and painstakingly charred. Located here Judging by it being at the same auction location, it would seem that this vehicle suffered its fate aside the previous. Is there any sort of value added for the two vehicles having suffered the same immolation?
Nice example, but I would keep looking, and would certainly encourage engaging an NCIS member in assisting you in your purchase or planning out your project. A local chapter member can be invaluable in helping plan your incineration as well as optimizing potential claims while limiting unwanted collateral damage.
Serious question: Could one of these be John Hibbeler's?
http://www.stltoday.com/news/local/c...a4bcf6878.html
One of the hottest Big block Mid Year Vettes that ever crossed our stage.............
Mostly stored in a "warm" climate..................
All the original parts have been retained.. (maybe in a lump somewhere)
ROTISSERIREE type restoration..............true indeed at the start of it all almost like a BBQ
No Expense spared in this restoration.... true enough!
Carefully maintained by a First Responder!
Talk of the town!
No car wash brushes... only cleaned with a hose!
Just like it arrived at the plant (foundry)
Only "put out" ONCE!
Pristine Original!!!
***** OK, now add your future comments*************
Marty
1FUNZR1
