62 Fuelie
Old 08-26-2013, 09:23 AM
chum
3rd Gear
chum's Avatar
Default 62 Fuelie
I am looking at a 62 original fuel injection Corvette with an incorrect aspirated engine. If I get it, I will want to first get a 327 engine. My question is this; is there any difference (cam, heads, etc) between any period 327 engine and a fuelie 327 of 1962?
Old 08-26-2013, 09:28 AM
ohiovet
ohiovet's Avatar
2016 C1 of Year Finalist
Differences in various 327 engines:
Cams
lifters
heads
pistons
etc.....
Old 08-26-2013, 09:30 AM
zangx1
zangx1's Avatar
461 heads. 097 can or equivalen. RF suffix
on the block.
Old 08-26-2013, 09:44 AM
chum
3rd Gear
chum's Avatar
Ok thanks for the info. I can't imagine that the chances of finding one of those is high, not to mention the FI unit. Are they available and if so, do you have any idea of the range of cost? Also, is there any source to run the VIN for the car and what can you learn from it other than the normal decoding? I understand that there was no trim tag like I have on my 57 Belair (color, acc, body style, etc). So, for my car, as long as you have a "period correct" engine, trans, etc. it is considered equivalent to "numbers matching". Is the 62 Corvette the same deal?
Old 08-26-2013, 12:57 PM
Ironcross
Ironcross's Avatar
wrong engine never comes in as matching numbers in anything, including 62 FI Vettes......
Old 08-26-2013, 02:52 PM
Zoomin
Support Corvetteforum!
Zoomin's Avatar
2018 C2 of Year Finalist
St. Jude Donor '12-'13-'14-'15, '19
I'm curious to know what the selling is offering as proof it was a fuelie car.
Old 08-26-2013, 03:11 PM
chum
3rd Gear
chum's Avatar
Good question. That's why I was asking what information you can get from the VIN as there does not seem to be any other tags on the car. The owner says that the car had no engine when he bought it in 1962. He points to the location of the windshield washer bottle with heat shield on the passenger side of the engine and the high redline on the tachometer as indications that it was a fuelie. The car also has the air duct running out to the front on the driver's side. Lastly, while easy to tack on, the car shows the fuel injection badge on the outside. Are there other ways to tell?
Old 08-26-2013, 03:19 PM
Zoomin
Zoomin's Avatar
There's no help to be found from the VIN. The next best thing is paperwork from the selling dealer.
Old 08-26-2013, 04:46 PM
MikeM
MikeM's Avatar
Received 1,843 Likes on 1,398 Posts
Almost every part on/in the block/heads of a SHP 327 engine is different than the lower horsepower engines. Even the main caps on the block are different.
Old 08-26-2013, 05:07 PM
OC-1
OC-1's Avatar
See posts #11 - 14
It's all about dimples in 62
http://forums.corvetteforum.com/c1-a...62-fi-car.html
To 62 Fuelie
Quick Reply: 62 Fuelie
