What engine do I have?
2023 Restomod of the Year Finalist
When I purchased my C1 four months ago, I was told the engine was a '69 Camaro 350, 300hp. I looked up the casting numbers but it doesn't seem definitive enough. Can someone tell me what I have?
Engine casting is 3932386, s/n V0827HU, heads 3932441, intake 3927184. Carb is a Rochester Quadrajet.
Actually, you have everything you need. That particular '69 block had 4 bolt mains. The heads were used with both 327 and 350 blocks and the intake manifold was used for all three HP configurations...250, 300, 350 in '69. Just mate the appropriate cfm carb, possibly the 4MV Rochester 7029202 DH, if you're looking for originality
Never mind, I found the marking. It is a 7029202 dh. So, guess the PO was correct, it is a 300hp!
Thanks everyone for clearing that up.
A carb swap won't do much.
It's still a 255 hp motor. The heads make the differance. The 300 hp would have heads with smaller combustion chambers around 62.8 cc's if I remember correctly.
Jim
PS- The 255 engine is a good combination because of the lower compression.
Jim
The stock valve diameters were 1.95/1.50 @76cc. Don't know what cam or compression ratio. I assumed from reading the original post the OP already had the makings of a 300hp...just needed to verify everything such as the Rochester carb described as it was used with the 300hp in '69 for that configuration. Just trying to be helpful without bustin' the guys chops!
