4 post lift, diy or not
Received 1,763 Likes
Thanks for all the replies. Going to order the lift tomorrow, Direct Lift Pro Park 8, they have stock so l should have it installed by the end of the week.I told my son not to make plans for a day that l need him.Will post pic,s and tell you how it goes. Cheers, Elio
My experience - a DIY project, but only if you are ingood shape (able to lift heavy stuff) or have access to a helper who has some beef.
My experience assembling my 4-post lift: Superlift Assembly post
Have install all the lifts in my shop, Just need a 4 wheel dolly, a floor jack and a cheery picker. And a little help. Use your brain not your back when moving and installing the ramps and you can do it in an afternoon. Before you break out the beer.
Mark
Mark
Is your garage floor sloped? Depending on the amount of the slope you have, you may also have to shim up one end of the lift to account for the slope. Although not necessary, I opted to bolt my lift to the floor for added peace of mind. If you do decide to bolt it down, try using the lift and moving it around a bit before doing so; to find the best location and proper clearances for it. Take it slow, use dollys and an engine hoist to do the heavy work and it will go fine.
You will wonder how you ever did anything without it!
Ray
Ray
Installed myself had it deliverd on a tilt flatbed. I had a dolly at one end so it made it easy to get it into the garage. I used an engine hoist to put it togeather myself. Good Luck
Important to level it . I had to shim mine under the bottom plates.
Well , thanks to all the replies given on my post and i,m glad my son and l put it together.We,ll know how to repair or dissassembly for next time. The lift that l got was a Direct Lift Pro-park 8S. Cheers
