64 speedo repair
Old 08-15-2013, 08:31 PM
Fwellman
2nd Gear
Fwellman's Avatar
Default 64 speedo repair
I am not sure if this is the correct area to post, but I have a 64 Vette and the speedo needs repair. The speedo more or less works, but the needle bounces a lot and the indicated speeds are way too low.
Does anyone know of a reliable place that can repair/re-calibrate the speedo? I would prefer Cleveland area, but I would be willing to ship it almost anywhere if the shop is well recommended.
Old 08-15-2013, 08:39 PM
66jack
66jack's Avatar
If its stock, try replacing the inner cable first...could be getting ready to break...
Old 08-15-2013, 09:05 PM
rick1542
Support Corvetteforum!
rick1542's Avatar
I'll keep an eye on your post. I am having a speedo issue to, Its 10 mph slow. I too am from the Cleveland area.
Old 08-15-2013, 09:17 PM
1snake
1snake's Avatar
Surely the Cleveland area has a speedo repair shop. If that's where the problem lies, take it to one of them. There's NOTHING special about a Corvette speedo that requires it to be sent out for repair. A local repair not only saves you on shipping and the possibility of being damaged/lost, you'll get it back in a day or two.
Old 08-15-2013, 09:45 PM
ben dover
ben dover's Avatar
Location: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
Bouncing indicates a broken cable, be sure to graphite the new one.
Old 08-15-2013, 09:55 PM
Mike67nv
Mike67nv's Avatar
2018 C2 of Year Finalist
2015 C2 of the Year Finalist
I’m not so sure your local speedometer shop (if one still exists) is going to be able to fix a C2 speedometer, especially if you need parts (gears, odometer, etc.) or refacing. To calibrate the speedo, the shop will need gauzing equipment.
There are plenty of shops around the country that specialize in C2 gauge work. Not in Cleveland, but I would recommend Corvette Specialties of MD (West). They did an excellent job on my tach and speedo including refacing, new gears, new odometer and calibration.
Bouncing indicates something is binding – cable, gear, or odometer. Inaccurate readings indicated magnet re-gauzing is required.
Do a search and you will see the many shops recommended. Then call around and get estimates on the symptoms you’re experiencing.
Old 08-15-2013, 10:03 PM
Fwellman
2nd Gear
Fwellman's Avatar
Default 64 speedo
It is a brand new cable. I installed a Tremec 5 speed ( well worth the money by the way), and the cable and gear came with it.
The tech guy from Tremec used to do speedo calibrations and said that this speedo works with magnets. He said that the bounce and variations in displayed speed are cause by weak magnets.
Believe it or not, there are no shops in the Cleveland area that will work on this speedo, ( that I could find) I checked before I posted.
Thanks for the tip on the out of state shop, I will give the, a call.
I tried an Internet search and came up empty. I must be using the wrong parameters....
Old 08-15-2013, 10:22 PM
1snake
1snake's Avatar
As told to me by the local speedo repair shop, "Corvette speedos are no different than any of the other 100+ million GM products of the same era and we all get our repair parts from the same place". I've had several C-1, C-2 & C-3 gauges fixed locally without a problem. No need to ship them anywhere.
Old 08-15-2013, 10:33 PM
67's
67's's Avatar
Try Bill Harrison at
http://www.harrisonspeedometer.com/
Great guy to deal with and top notch work.
To 64 speedo repair
Quick Reply: 64 speedo repair
