C1 Electrical Wiring Issues
Old 07-30-2013, 01:41 PM
blackvette58
blackvette58's Avatar
Default C1 Electrical Wiring Issues
Recently installed new wiring in my 1958. Everything works fine except the interior light and heater motor. Any suggestions for how to go about finding a remedy? Thanks.
Old 07-30-2013, 01:44 PM
jimh_1962
jimh_1962's Avatar
2018 C1 of Year Finalist
check the grounds and check the connections. You might need to clean the connections off. I would check to see you are gettiing power the end of the wires. The interior light works off of the headlight switch check to make sure it is connected. Did these items work before with the old wire harness? Fuse?
Old 07-30-2013, 02:12 PM
JohnZ
Support Corvetteforum!
JohnZ's Avatar
Received 1,856 Likes on 1,099 Posts
The heater motor has a really flaky design for grounding (through the outer temp cable coil wrap to the rear side of the center console faceplate). Add a secondary ground wire from a blower flange screw to a known good ground and it'll work fine.
To C1 Electrical Wiring Issues
Quick Reply: C1 Electrical Wiring Issues
