broken ring rough.
Old 05-10-2013, 10:46 PM
jimh_1962
jimh_1962's Avatar
2018 C1 of Year Finalist
Default broken ring rough.
Now the vacuum reading, rough idle, slight overheat and the oil on the plug makes sense... The cam looks fine so I think I can take the heads off and have the valves checked out once more and remove the piston from the top to replace the bad set of rings.
[IMG][/IMG]
The rest look good!
[IMG][/IMG]
Some burn marks from #5 on #4.
[IMG][/IMG]
Old 05-11-2013, 01:33 AM
AZDoug
AZDoug's Avatar
Received 1,478 Likes on 905 Posts
C1 of Year Finalist (performance mods) 2019
2017 C1 of Year Finalist
Those are some nice pics. Not sure what I am supposed to be seeing in pic #1, but it does remind me how close everything come during rotation.
Doug
Old 05-11-2013, 02:34 AM
jimh_1962
jimh_1962's Avatar
Picture #1. Look at the burnt deposits underneath the #5 which was fouled. This motor has less than 500 miles so it should be very clean underneath which is the case with all of the other pistons. I found two small non-magnetic fragments on the pan which are quite bendable (broken ring). I think this is causing the rough idle, weird vacuum readings, fouled plug and slight heating condition. I bet the inside of number 5 has lots of oil burnt inside. I guess it is easy to check just time and a new set of gaskets... I thought maybe it was timing. Now, I think the ring is not sealed or partly broken on #5 since it was the one where I have been seeing some smoke on that side including oiled spark plug plus a lot of burnt underneath the piston.
Old 05-11-2013, 08:59 AM
Matt Gruber
Matt Gruber's Avatar
far more common to have a poor sealing intake gasket. was it retorqued at least 3 times in 500 mi?
Old 05-11-2013, 12:30 PM
jimh_1962
jimh_1962's Avatar
yes, I torqued it down a few times during 500 miles.
Old 05-11-2013, 06:15 PM
JohnZ
Support Corvetteforum!
JohnZ's Avatar
Received 1,856 Likes on 1,099 Posts
Rings are magnetic (attracted to a magnet).
Old 05-11-2013, 07:29 PM
thoyer
thoyer's Avatar
Plus they are not very "bendable".................
Old 05-12-2013, 02:45 AM
jimh_1962
jimh_1962's Avatar
Not a ring! It is the oiler spacer. The thin ones which goes top and bottom of the oiler (not sure if the term is right). Now, I am definitely getting somewhere to the cause of the missing and vacuum readings. What would cause one of those to fail?
Time to pull the intake and the heads off. I will have the valves looked at when I pull the heads. Plus, check the other pistons for any wear. I might be looking at taking each one out and inspecting the rings.
I guess I would need to inspect the cylinder walls and hone it??? Not sure with such low miles.
Old 05-12-2013, 01:32 PM
AZDoug
AZDoug's Avatar
I think the wavy oil control rings spacer is magnetic, also. You may have pieces of piston ring land, those are non magnetic aluminum, but they would have to be pretty thin to bend.
Why not post pics of the pieces?
Doug
Old 05-12-2013, 03:23 PM
jimh_1962
jimh_1962's Avatar
I had another package and compared it. Sure enough it is the same thickness and material. These are not magnetic but figured out what it is. I will take pictures of the piston once I pull it.
[IMG][/IMG]
Old 05-12-2013, 03:29 PM
jimh_1962
jimh_1962's Avatar
Now the question is what do you think caused it?
Old 05-12-2013, 06:18 PM
jimh_1962
jimh_1962's Avatar
ideas of what caused the part to fail? I might have to replace the piston also right?
Old 05-12-2013, 07:24 PM
JohnZ
JohnZ's Avatar
Well, what is it - piece of piston skirt?
Old 05-12-2013, 08:46 PM
jimh_1962
jimh_1962's Avatar
One of the spacers on the oil ring. Same metal.
Old 05-12-2013, 08:52 PM
jimh_1962
jimh_1962's Avatar
the oiler spacer...
[IMG][/IMG]
Old 05-12-2013, 08:54 PM
jimh_1962
jimh_1962's Avatar
John, any ideas why the part failed? Lots of fun work ahead... This is the second time I am going to take the heads off to get to the part. I am going to take both heads off and have them checked. I guess I could pull each piston and check them all. I did not see any problems with the other pistons. The spark plugs looked fine in the other cylinders.
Old 05-12-2013, 08:56 PM
jimh_1962
jimh_1962's Avatar
Also, I thought I had wiped the cam since it was off when it was running. But that's not the case. I could see the cam from underneath and it looked good.
To broken ring rough.
Old 05-12-2013, 09:03 PM
midyearvette
midyearvette's Avatar
what kind of rings are you running??.....
Old 05-12-2013, 09:13 PM
jimh_1962
jimh_1962's Avatar
Sealed power E-251K-30
Bore (in):4.030 in.
Bore (mm):102.362mm
File Fit:No
Top Ring Included:Yes
Top Ring Thickness:5/64 in.
Second Ring Included:Yes
Second Ring Thickness:5/64 in.
Oil Ring Included:Yes
Oil Ring Thickness:3/16 in.
Oil Ring Tension:Standard
Gapless:No
Top Ring Material:Iron
Top Ring Facing Material:Moly
Second Ring Material:Iron
Second Ring Facing Material:Cast iron
Oil Ring Material:Stainless steel
Quantity:Sold as a set.
Old 05-13-2013, 12:53 AM
jimh_1962
jimh_1962's Avatar
would fuel wash cause it to fail? If so, can just get away with re-honing the block? This motor has less than 500 miles on it.
Quick Reply: broken ring rough.
